As PC starts watch screen for message "to enter setup press del" or similar. (press F!, press F2, press F12).Power down the PC and then power it back up. Be ready to press the KEY to enter setup while message is on screen. If you do not see the "enter setup" try holding the delete key as machine powers up.
Then repeat while holding F1 key etc. Once you enter setup (CMOS SETUP) find the boot settings and select CD as first boot drive. Put your full install CD in the CD drive have the license code ready. Example; AB123-1RD5C-XP94D-MN47G-LRIPQ. Your key will be on the CD sleeve or license sticker on PC. With install CD in drive power PC up. The PC should boot from the install CD. Do a full install on C drive. This should format your C drive erasing everything on drive C. Format with NTFS (new technology file system). During install the PC will restart a few times. At one point it will require you to type in license code. About half way thru install you will be instructed to remove all disks from drives, at this point you enter setup (CMOS) again and change from boot from CD as first choice TO boot from HD and second choice boot from CD. If you can not complete install you may have a hardware problem. GIVE plenty of time for each install step. Install may appear to have stopped but it will continue when it has completed that step.
When you restore your system back to the new factory settings, it will wipe your hard drive clean and do a fresh install of the operating system with the original factory setting.
To start this process, unplug all extra devices from your computer
(printers, external hard drives, etc.) as these can interfere with the system restore.
Starting with Windows XP, most systems with issued a system recovery disk in case of any problems with the factory installation.
Check the documentation and disks that came with your computer to determine if you have one of these system disks.
If you do have a copy of this disk, place it in your CD/DVD drive and restart your computer.
If you do NOT have a copy of this disc, skip to step 3 for further instructions.
Once you restart your computer, a screen will appear with the words.
Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings.
Follow the on-screen prompts to finish the installation.
Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again.
Restart your computer to complete the restore.
3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk.
Unplug all external devices and restart your computer.
When the loading screen comes on with the Windows logo, press Alt+F10 together five times.
This will bring up the system restore menu.
Follow the on-screen prompts to restore your computer back to the factory settings
hope this helps
