When i plug a usb device into my dvd player a message pops up saying usb device not supported,i tried re formating the memory sticks and the player just wont recognize them
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
Format to FAT32
Posted on Oct 19, 2013
4 Suggested Answers
SOURCE: I've downloaded a firmware update
today i solved following errors on sharp blu-ray hp20 when updating software to play quantum of solace:
can't detect software: due to .rvp file being inside a folder--not in root directory on usb stick
more than one software file detected by player: .rvp hasn't been properly unzipped. the 2 gb disc and, as far as i could tell, my system (imac os 10.5.6) showed successfully extracted SINGLE file ready for transfer to dvd player, but dvd player said that there was more than one file. erased the 2 gb disc with disc first aid utility as part of exercise. also verified FAT format on 2 gb disc. only after i used a downloaded free mac utility *specifically for extracting ZIP files* to transfer the .rpv file to the 2 gb disc did the dvd player recognize the file and i successfully updated the player's software! (sorry for the run on, i think the logic is accurate)
Posted on Mar 28, 2009
SOURCE: Sharp BD HP21 Won't recognize USB drives
You have to make sure the files, you downloaded to your USB stick, are not in folders. Mine worked after this. I am still having problems with pixelation on newish discs. I read somewhere that if I plugged a USB thumb drive into the Sharp HP21 it will aid the processing and work better. Does anyone know if this is true as I often get poor picture quality on what looks clean LoveFilm BR discs. (No problems with standard DVDs.)
Posted on Oct 06, 2009
SOURCE: Trying to update firmware on
I had the same problem and immediately suspected that, as I had downloaded and expanded the .zip file on a Mac, I was suffering from the industry's usual bovine shortsightedness and that I needed to do it on a PC. I did and it worked. So I think the important part is to un-archive the .zip file on a PC, and find the file inside the resulting folder called
BDP12X_149.MVP
Make sure you have just that file on your USB stick, and no folders, and then the player should recognise it. You'll note that Pioneer's instructions don't mention this file name at all. Useless. Wish I'd bought another brand.
Posted on Dec 29, 2010
Can you watch a film off a memory stick
Usually you can if it is a USB 2.0 or 3.0 port. Depends on the video format too. (.avi, .mov., MPEG...)
May 23, 2015 | Televison & Video
Panasonic sa pt860
Check your USB memory to make sure that it comply with the points below:
1) USB standard USB 2.0 full speed
2) Media file format support MP3 (.mp3) WMA (.wma) JPEG (.jpg) (.jpeg) MPEG4 (.asf)
3) USB device file system FAT12, FAT16, FAT32
4) USB Port power Max. 500 mA
As you can see
1) You should format your USB in windows format (FAT system)
2) The files on your USB should be those mentioned above on point 2.
3) 2.5" hard drives most likely do not work without an external power supply.
you can download the manual from HERE !
Please don't forget to rate me!
Best Regards
XyFinx
Dec 14, 2013 | Televison & Video
I am trying to make a dvd from a HDD video cam to a sony DVDirect recorder VRD-MC3 and a message saying non supported USB devbice keeps comiong up. Can you hellp?
The manual of the DVD doesn't say much for models, say's sony HDD, sony DVD, so maybe it's not compatible. Do you have a memory stick for the handycam ? If you stored the video on the internal storage, check the manual to see if you can move it to the memory stick, then put the stick into the DVD player. Or you will need a PC to transfer it with USB, then get a memory stick and put all the video on in and not internal storage, if the DVD is not compatible with the handycam.
Mar 30, 2013 | Sony DVDirect VRD-MC3 DVD Recorder
Hi, I have a Samsung DVD Player H1080 R. Nice player with sleek design. When I try to connect my Seagate Go Flex USB 2.0 Plug & Play (1 TB), it doesnt play. There is data in the external hard disk,...
Good day!
These are the 2 possible causes and solution on that problem:
  • The format of the file on U.S.B device is not compatible to the format requirements of the DVD player.For example your DVD player required A.V.I or MPG/M-PEG for the video while the file format of your U.S.B is F.L.V and when you try to insert it to the U.S.B port the file doesn't read.You have to do is convert the file that store on your U.S.B device depends on the format requirement of your DVD.Use a total video converter to convert the file on your U.S.B to the format you need to play on the DVD player.
  • Or the problem could be the U.S.B itself,because the U.S.B host on this product does not supported all U.S.B device.Please try to use other mass media device such as memory card or mp3 players.
I hope this solution will be helpful.Thank you.
May 02, 2011 | Samsung DVD-H1080R DVD Player
When attempting to update my bdp-120 blu-ray player, I continue to get an error message saying I have more than one sofware file on the USB memory device. The only file on the device is the update. How can...
You need to format your usb memory device which will mean that everything will be erased from it so move anything you want to save first. Before you attempt to place the file on the usb device again make sure it has been unzipped first.
Feb 05, 2011 | Pioneer BDP-120 Blu-Ray Player
Can't play my 4GB Transcend on a JVC DVD player... the player has a USB port, and it works with other USB's... My Transcend worked before. I reformatted it because there were viruses though. And when I...
Hi Aking,
let's start at the begining,
you'r usb stick has been infected and you formatted it.
Did it ever work with the player?
Assuming it had.
Often this sort of stuff happens when file format is incompatible with the device. New operating system of a PC used to reformat might cause it. If you could refer to the manual of the player and check which usb formats it supports then move the data off the usb stick and reformat it according to the specification,
you should be able to put the data back on and it should work.
If above didn't help time to blame either of the pieces of hardware: usb stick or usb port on the player.
Sep 05, 2017 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How can i identify the usb ports on my computor? I am running a rebit backup and it says it runs faster on a 2.0 usb. I have three ports but not sure what speed they are. Thanks.
Take a recent USB memory-stick, that supports USB 2.0.
Stick it into one of your USB slots.
If the balloon pops-up to say "this device will run faster in a USB 2.0 port", you have just plugged it in to a USB 1.1 slot.
Unplug it, and try the next USB slot.
Perhaps, *NONE* of your USB slots will support USB 2.0.
Dec 08, 2009 | Sony VAIO VGN-FS550 Notebook
Xo vision dvd player/receiver 1906 wont read my usb or SD disk.
Consult the manual, it should probably say something about external media.
Check what kind of disk format is supported by your player - some players will recognize an external usb disk (or a usb memory stick) only if it's formatted in FAT32 file system.
Note that if you format the disk on a Windows machine, it will only do it on drives with a relatively small capacity (i think it's up to 32 GigaBytes), but other operating systems (like MAC OS) can perform a FAT32 format even on drives with far greater capacity.
As for the SD disk (did you mean a SD memory card?), see what the manual says about the format type, have the card (disk) formatted in the supported format and see if that works, otherwise you might want to try other brands of SD cards - my friend has an Avia (not Aiwa) dvd player with a usb port and a SD card slot and it simply won't accept some brands or models of SD cards, but will work well with others and it also works well with USB disks and USB memory sticks formatted in FAT32 file system.
That's about all i could suggest, i hope you can get it to work.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Televison & Video
Every time I plug in USB stick the message on the screen says not supported. Only Divx files and Jpeg photos are on the stick but it will not open.
Hi...
I that situation it is possible, when you plug it in the USB stick the data will not be supported. because they are not in the same format, you need to install the Divx so that i will be read by the USB stick,
Good luck !!!
Regards
PCmania
Jul 10, 2009 | Toshiba Televison & Video
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
