Question about Kyocera TASKalfa 180 Copier
My machine prints one side light - Kyocera TASKalfa 180 Copier
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 45 Answers
Chek leser unit
Posted on Oct 19, 2013
Ink cartridges just replaced and print is coming out light gray. #2 When I print e-mails or documents from e-mails--advertisements and side bars print out on my documents? Can you help me fix these...
first off the side bars printing is the direct result of the settings you are using. and must be readjusted. accordingly. The light gray print sounds like a combination of 2 separate settings, the "economode" that is set on the printer itself, and a similar setting in your print mode on the computer (never use both, only one or the other).
Mar 27, 2015 | HP Photosmart 7510 e-All-in-One -...
Tip
Intellifax 2750 Prints light on one side
Brother Intellifax 2750. Prints light on the left side of the paper (left being it's out of the fax and you're looking at the paper). Changed cartridge and it's still doing it. What ya think? Thank you in advance.
on Aug 12, 2008 | Brother IntelliFAX 2750 Plain Paper Laser...
Fax machine print light
When you see light print it can be from a few things. This is basically a laser printer with a fax machine so the same problems exist in both. The most common cause by far is simply low toner. If you take out the toner cartidge and gentl shake it side to side then put it back in. Now try printing again. This should be much darker. This may only last a few dozen pages (but can go a quite a bit more if you are lucky) but it shows you that you need to get a new toner cartridge. The other causes can be a image setting in the fax. In the control panel it will show you a setting for how dark it will print. Normally it is in the middle of the range. The last common thing is a fusor wire. This normally shows up as a error first but it can slowly fail. The fusor is the heater that bonds the toner to the paper. If it doesn't get hot enough then not all the toner sticks and you get light printing.
Normally the problem is low toner.
Jan 10, 2012 | Panasonic KX-FL511 Plain Paper Laser Fax
Kyocera mita km-1820 not printing clear copies
you have to check the duplex unit on the machine itself.
May 01, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Machine will not print double-sided documents
Try resetting the NVRAM from the diagnostics screen.
Apr 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Light printing
we cannot figure out why the fax/copyer always prints things out very light you cant see any thing that gets printed out on it
Jul 09, 2008 | Brother IntelliFAX 2800 Laser Fax
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
Kyocera TASKalfa 180 Copier Logo
32 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
