Question about Bosch WAS24460UC Energy Star AXXIS Plus Front Load Washer
We have a Bosch classixx 1200 washing machine which has a timer style fault. The machine shows no fault codes. When a wash programme is selected is may be say 45 minutes long. The programme is started and the clock counts down to 1 minute. It then sticks on one minute for say 10 minutes and resets to 20 minutes and then counts down from 20 to one again. In short a wash is taking a lot longer than it should. We have switched the machine off and on at the plug to try to re-set it. This has had no effect.
5 Suggested Answers
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Posted on Jun 04, 2009
  • 662 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 17, 2010
  • 6277 Answers
SOURCE: We have a Bosch classixx
It is possible that the heater is taking longer than it should to heat the water to the correct temperature. This could be that the element is coated in calcium. I suggest you run the contents of a couple of sachets of proprietary limescale removing powder/fluid through it. The most efficient way is to put the contents in an empty washer and pour a kettle of hot water into the drum then leave overnight. In the morning run just a spin; the water mix will then go through the drain filter and drain motor impeller blades, doing absolutely NO harm whatsoever, in fact some good!
You could also consider repeating the action ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 05, 2011
Macmarkus
  • 2605 Answers
SOURCE: I have a Bosch Classixx
Hello David, welcome to FixYa.
I understand you have a concern with a WFL2066 series Bosch washer, specifically what is believed to be a filling and doing nothing else, correct ? I'll also presume there are no error codes present...or that you are aware of ?
The fisrts step may be to start a test program and see what comes of that and to quickly look at the back and inspect the status of the belt. To test...(If it is too small let me know I'll try and break it up into segments & re-post)
(most times a scenario like this involves simply the belt being spun off or breaking thus requiring just put back on or replacement. Other times it is the motor brushes).**Unplug the unit from the wall before removing panels or performing any service...safety first**
The back panel must be removed on the WFL for inspection, and to do so is as follows...
To remove rear panel to access drive motor and rear of drum, remove (7) T-20 & (4) T-30 Torx screws and gently lift panel up (off of tabs at top of panel).
example:
From this vantage point you should be able to see if the bely has come off or not, if not you'll need to examine the motor which will require more involved investigation and you'll need a multi-meter/voltage meter.
example:
Let me know what comes of this or if anything is not clear and I will continue to assist you going forward if necessary.
Thank you for choosing FixYa and good luck. If this does provide you with a solution please take a moment to rate the assistance and a brief testimony is appreciated as well.
Regards,
Macmarkus :)
Posted on Sep 13, 2011
F21 flashing on my bosch classixx 6 1200 express
F21 is a motor fault and in some cases can also involve a module fault. It could be as simple as the brushes need replacing or the drum has been severely out of balance.
Mar 21, 2013 | Bosch Washing Machines
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
Error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Apr 05, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Bosch classixx 1200 washing machine stalling mid-cycle
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My Bosch Classixx 1200 washer causes the household RCD to trip
The first thing I would recommend u do is to remove the motor and check the carbons for wear, Their should be at least 3mm of carbon showing, any less then u shud replace.
The other possibility is a faulty heater element, u cud try it with the element disconnected, if it does not trip then the element is faulty.
Plz rate my solution.
thanks.
Dec 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch classixx 1200 express
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch WAS24460UC Energy Star AXXIS Plus Front Load Washer Logo
59 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
