Question about Siemens WFXD8400UC Front Load Washer
My washing machine will not work it keeps flashing f43
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
F43. Terminal?
motor brushes on bosch machines typically last 6-7 years its the first thing to check
Mar 19, 2014 | Bosch Washing Machines
Fault code to bosch washing machines f43
F43 normally indicates a fault with the motor or the main control board
Dec 22, 2012 | Bosch Washing Machines
F43 ON THE SCREAN
F43" error indicating "motor malfunction"
Oct 15, 2012 | Bosch Axxis WFL 2060 Front Load Washer
F43 ON THE SCREAN
Oct 15, 2012 | Bosch Washing Machines
F43
Hi.
If you have Bosch, Baumatic, or any other machine built by Bosch, then F43 is a motor issue:
Error F43 : Motor fault: do an emergency drain through the drain access in the front bottom side (see manual). Open door and check ig the drum rotates free when spin by hand. Disconnect power before performing maintenance.
Regards.
Ginko
Sep 14, 2011 | Washing Machines
My new bosch logixx front loader washing machine (3 weeks old) is showing a flashing error code F:43....what does this mean ? Thanks
I just realised that I don't appear to have a comprehensive list of Bosch error codes, but some quick research tells me that F43 is a motor error, usually associated with the motor brushes requiring replacement (Though they may also be sticking and just require removing, cleaning and re-fitting).
Jun 30, 2011 | Washing Machines
Siemens WFXD8400UC Front Load Washer Logo
55 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
