Question about Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902
In my machine when we switch on the machine the code c- 12c0 appear
    Problem Solver:
  • 19 Answers
The C-12C0 code is a hard disk drive failure. Try to remove the hard drive and see if that solves your problem. You wont be able to scan big documents, but it should do the trick. Otherwise you'll have to get a new HDD of the same size that's in there. A bigger one won't work.
Posted on Oct 21, 2013
Rumam855@gmail.com
Ruman Khan
You can try this Activation code:
452F-0312-EE82-F12D-12C0
Feb 24, 2014 | Corel Computers & Internet
Error code 12C0
Hard disk failure or the hard disk is gone
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 12, 2013 | Konica Minolta Bizhub C350 Digital Copier,...
CODE E4 ELECTROLUX EWT64S FULLY AUTOMATIC WASHING MACHINE
In my experience, E4 is appear when spin is starting. Then I check the 'magnetic door safety switch' and gotcha, I find the problem --> 'magnetic door safety switch' is damage (always open). Because some reason, I am short-circuit it. Fixed.
Oct 11, 2012 | Washing Machines
How to set value 08 mode code 695 set value to 0
Hi
Please switch of the machine.
While holding buttons [0+8] down, switch the macine on, when [ad] appears in the display remove the fingers.
Now key in [695] and press the start button, when [1] appears in the display input [0] and then press the interupt button.
[Ad] will then reappear in the display, now input [971] and press the start button, make sure that value is [3] and then press the interupt button.
Switch off the machine and then switch back on to take it out of the test mode.
Those two codes will disable the machine checking for toner.
Apr 11, 2011 | Toshiba e-Studio163 Copier
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
Minolta biz hub 250 ...problem error code c3451
Hi there.
Please try .
Try this.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will requir
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 14, 2009 | Konica Minolta bizhub C250 All-In-One...
Dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
Jan 11, 2009 | Maytag EPIC MFW9700S Front Load Washer
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Sep 02, 2007 | Hotpoint Aquarius WD640 Front Load...
Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902 Logo
79 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
