Question about Panasonic Center Speaker Sb-hc480 Home Theater Surround Sound System Sc-bt228
How to change laptop connecter speaker - Panasonic Center Speaker Sb-hc480 Home Theater Surround Sound System Sc-bt228
    Problem Solver:
  • 5 Answers
It is on-board u had to remove complete socket and plug the new socket
Posted on Dec 20, 2013
I have set up the speakers and on my PC control panel it says the speakers are connected, but when i play music on my PC (Sony vaio) the sound still come out of the PC not the speakers. do i need t change...
Try this. Go to the control panel in Windows (all versions) and select "Sound". Below you can see the sound control panel from my computer. See those greyed out ones they are inactive outputs that have been disabled. At the bottom is the speaker output. Depending on how your laptop is configured the output may need to be changed. Right click those available, and enable them, then select them one by one while playing a tune to see if one of them is the output connected to your computer speakers.
Mar 13, 2015 | Microsoft Computers & Internet
I have y560 lenova idea pad with TV tuner.i want BIGTV connect to laptop
Hi krahul17,
I see that you want to connect a BigTV to your Y560 Laptop, I can give you a few details on what you can do to conenct a bBig TV to your Laptop.
- Your Y560 has an HDMI port on it and you can use HDMI to connect an LCD TV to your Y560 Laptop.
- In Windows7 lower right side of your task bar you will see the speaker icon right click on it and it will give you options, see below image.
- Click on Playback Devices
- You should see the sound window inside the window you will see a list of audio devices on your system, you should see your HDMI first on the List with a Picture of an LCD TV next possibly will be your speaker which is set as the Default device the last should be Realtek High Definition audio device.
- Right click on the HDMI and select set as Default Device once set as default device your HDMI video and audio should work but if you connected your Laptop to the TV before you changed this settings you will need to restart you Laptop for the changes to take effect on your system and also make sure that the input for your TV is also set to HDMI to make everytihng work.
- And if you will be going back to using you Laptop only you may need to go back to the sound window to set the speakers as your Default device to make the audio come out from your Laptop Speakers.
I hope that this will be of help regarding your concern, have a nica day.
Mar 23, 2011 | Lenovo IdeaPad Y560 Laptop
I have had my Advent Modena M202 laptop for 3 weeks now. At first the built in speakers were working, then the left speaker cut out and stopped working after 1 week, the right hand speaker has now cut out...
This could be one of two things;
  1. There is a wiring, connection issue from the laptop to the speakers.
  2. There is a driver issue. Try clicking uninstall on the speakers. Under device manager, right click the speakers and click uninstall, and then click scan for changes. This will attempt to install the newer drivers.
Mar 15, 2011 | Computers & Internet
I cannot hear any sound in my laptop computer.
Hi brightmensah
Try the following.... *Try to install the audio driver again(if you are getting symbol like this
*If you are not getting this symbol check your speakers by connecting a headset or any audio device to Headset If you are getting sound on headset means this problem is related your speaker connections it's better to contact service center or you can log to www.insidemycomputer.com to change your speaker or it's connections.
Thank you
Jan 30, 2011 | Toshiba Satellite 1805-S274 Notebook
No sound in the inter speaker! except if I connect external speaker or headphones!!!
As sound is coming to external speaker then need to check the connection or change your laptop speakers.
Aug 21, 2010 | HP Compaq 6720s Notebook
Paired with my laptop but no sound comes out of the speaker. my laptop still plays throuugh its own speakers.
Although I have a different model, I was having the same problem. By right clicking on the speaker icon next to the clock in the icon tray you'll get different options. Click on 'Playback Devices' and then you'll see all the speakers that are active. In my case, the default speaker was set to be my laptop speakers (you can see this because of the green dot). By simply changing the bluetooth speaker to be your default speaker (by right clicking on it) you'll hear sound again. And when the blueetooth speaker is disconnected, the laptop use your 'secondary' speakers, that is, your laptop speakers. Hope this helps!
Apr 18, 2009 | Yamaha NX-B02 Bluetooth Wireless Speaker
Connecting SRS-BTM30 bluetooth speakers to my vista laptop
This has also been sending me around the bend. I resolved it by disabling the speakers on my laptop. To do this go into control panel, then hardware and sound, then change system sound. Select your speakers and disable them. This allowed me to play music through the speakers. You can also re-enable the laptop speakers after this.
Jan 17, 2009 | Sony SRS-BTM30 Computer Speakers
External speakers for acer laptop 5220 series
Hi there
On acer laptop you have already speakers. but you want to connect external speakers then please find
that three conector in your laptop and connect you external speakers on one of them. please try each connector and you are able to connect external speaker.
Thanks
Robert
Sep 24, 2008 | Computers & Internet
Panasonic Center Speaker Sb-hc480 Home Theater Surround Sound System Sc-bt228 Logo
29 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
