Brother printer HL 4050 CDN Message showing unable print 2A . May be waste fulll but I clean still same error
3 Suggested Answers
SOURCE: brother HL 4050 CDN suddenly
The green tab slides from left to right.
This cleans the croner wire. These wire also have a tedancy to break every often.
The drum unit will need to be replaced
Posted on Feb 15, 2011
alpug
  • 1961 Answers
SOURCE: brother printer hl 4050cdn suddenly
First, try to check the release lever for the waste toner box. If this is OK you might be looking up to replacing the waste toner box cause this is the common reason for "Print Unable 2A" error
It is possible also that 2A is a fuser thermistor error usually caused by the fuser not heating properly and needing to be replaced. If the fuser is heating properly then the thermistat may be failing and need to be replaced.
I'm afraid a little help from a service technician is all you need, if you don't have experience for this kind of printer problem.
Good Luck!
Posted on May 01, 2011
Ive replaced the waste toner box in a Brother MFC-9140CDN but the replace WTB message still continues and I still can't print. Its supposed to last for 50,000 pages, its done 8,000 pages.
Check your operator''s manual for a reset procedure. If this doesn't work, pull the AC plug overnight, if the error isn't stored in a flash memory, this may help reset it.
Jun 25, 2015 | Brother Office Equipment & Supplies
Print unable 32
This is not just a density sensor, this is a plastic cover over it that is getting stuck. There is a piece of soft rubber attached to the solenoid that is getting very sticky over time. Removing this rubber and stretching solenoid return spring corrects the issue. Search web for the service manual and follow chapter 8 to disassemble the printer correctly - takes less than 10 minutes to do it
Aug 29, 2011 | Brother HL-4040CN Laser Printer
Brother printer hl 4050cdn suddenly stopped working print unable 2A message which I gather is some sort of hardware fault. Resetting no good.
Good Luck!
May 01, 2011 | Office Equipment & Supplies
Brother HL 4050 CDN suddenly got DRUM ERROR, and there're message slide green tab on the drum unit in
Feb 15, 2011 | Brother HL-4050CDN Printer
Printer won't print
..if not mistaken, the error message is Unable to clean, which indicate you will need to replace the waste ink pad and reset the waste ink counter.. you will need to send to the local service centre to get it done..
May 24, 2010 | Brother DCP 115C All-In-One InkJet Printer
Print unable 2A
2a is a belt cleaner release failure. May need a new waste toner box, or check the release lever for the waste toner box.
Nov 20, 2009 | Brother MFC-9440CN Laser Printer
Won't print error message 5b00 on screen. How can
5B00 is the waste ink absorber full message, only a Canon repair shop can reset the error code.
Jul 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Nov 09, 2007 | Brother MFC 420CN All-In-One InkJet...
jasbo
jasbo
