Question about Foxconn P4M9007MB-8RS2H Motherboard
P4M9007MB Motherboard Can I just a standard ATA HDD on this board rather than SATA hardware ? Thanks
  • robby_2008 Sep 27, 2007
    Thanks very much !
    One more thing to ask, Ive heard that you can use a 20 pin ATX power connecter on a 24 pin mobo, anyone know if this is true ?
    Reason for asking is because my PSU has a 20 pin ATX power connecter !
    Thanks
  • robby_2008 Sep 28, 2007
    Thanks very much mate
    All the best
  • 40 Answers
Yes, VIA VT8237A (stay as south bridge on your mobo) support ATA133. You can use upto two IDE/ATAPI devices.
Posted on Sep 27, 2007
  • Roman Sevko
    Roman Sevko Sep 28, 2007
    Some mobo with ATX-24pin can work with PSU ATX-20pin (to ex. more Asus, Abit), some can`t (to ex. Gigabyte, Epox, etc).
    If you will use voracious CPU (and/or videocard) - strongly recommended replace to new ATX-24pin PSU 350W (high-quality) and higher (for not high-quality PSUs).
Good day sir how do i connect a 500gig sata drive to a mother board ms 7142
Dear User, Good day, This is the specification of your motherboard. MSI K8MM-V Via Socket 754 MicroATX Motherboard / Audio / 8x AGP / 10/100 Ethernet LAN / USB 2.0 / Serial ATA. All you need is sata cables and an adapter if the power supply cable support only serial IDE. check this link for the photo of the adapter. http://www.buy.com/prod/ide-to-serial-ata-sata-for-3-5-hdd-pc-adapter-converter/q/sellerid/23962916/loc/101/214950013.html
Apr 16, 2011 | MSI K8MM-V Motherboard
Will a Quantum Fireball hdd replace a Sata hdd.Both are 3.5 and 5/12v or do you need to re configure them?
SATA (serial ATA) is a connection type, not a brand of hard drive. Any brand of hard drive will replace any other, as long as they are both SATA drives. The data and power connections are standard between drives, as are mounting dimensions. Normally, with SATA drives there are no jumpers or other configuration you need to deal with. Each SATA drive has its own connection to the motherboard, so you don't need to set master/slave jumpers like you would on the parallel ATA drives using the wide data cable.
Nov 14, 2010 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Can i use a sata hard drive with my ga 7vklm mobo
The Gigabyte GA-7VKMP motherboard does not support serial ATA SATA drives. Open the link provided; http://tw2005.giga-byte.com/Motherboard/Products/Products_GA-7VKMP.htm
2 x ATA 66/100/133 bus master IDE ports
1 x FDD, 2 x HDD and 1 x CD audio input
IrDA(1x5) and COM2 on board
GBT standard front panel
2 x USB2.0 connectors (support 4 ports by cable)
You can connect the adapter below to an opened IDE port and connect a SATA 1.5 drive to your system.
http://www.satagear.com/SATA-MM-A1_SATA_Adapter.html
This should allow you're SATA drive to transfer data faster than the 133MHz standard IDE speed.
Cheers'
Mike
Aug 10, 2010 | Gigabyte GA-7VKMP Motherboard
Looking for hard disk 320GB for my asus matherboard p5gd2-x which HDD sopport this matherboard help!!!!!
pretty much any brand will work. looking at the specs tho get a sata type drive as it appears you have 4 on that motherboard
Storage Controller Type(s) DMA/ATA-100 (Ultra) x 1, Serial ATA x 4
Dec 02, 2009 | Computers & Internet
Suport hdd sata intel d865gbf?
The Intel D865GBF motherboard.
Supports 2 Serial ATA (SATA) connectors, see page 39 in your manual.
The serial ATA SATA ports will support Version 1.5GBs SATA drives not 300GBs
If you no longer have your manual, download it from Intel. Click on the link below;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22d865gbf%22
Mike
Oct 15, 2009 | Intel D865GBF Motherboard
Does this have a SATA connection for a SATA HDD
I cant find specs or a good big pic so I can see it, the sata jacks are similar in appearance to usb potrs, on the Motherboard they are usually clumped together (If there's more than one), If it doesn't have them you can get a PCI card with SATA potrs and put that in.
May 11, 2009 | Matsonic MS8147C+ (N82E16813184008)...
Asrock Motherboard problems with SATA HDD
It is possible that you are trying to use a SATA II HDD in a system that supports SATA. SATA II devices are not backwards compatible usually,
Dec 20, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Thank you for using fixya.
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
Sata Port Connector is not avtivating
I had the similar problem with the K8MM-V Motherboard. I has been using a PATA HDD. I need to intall a 250Gig Seagate SATA HDD. Despit all the Bios Configs the PC Could not detec the HDD. Untill i Put a Jumper on the HDD  limiting the SATA HDD to 1.5gig of OS instead of 3gig. Look at the Label of your HDD
Oct 28, 2008 | MSI K8MM-V Motherboard
Hdd
your board may support sata however it may support sata 1 not 2 and your hdd may be a sata 2 one..so all you have to do is to check the hdd jumper and set it on sata 1 and also check the bios for the right settings to be made...
good luck
bye
Feb 09, 2008 | ASUS P4V8X-X Motherboard
Foxconn P4M9007MB-8RS2H Motherboard Logo
150 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Anders Bergwall
Anders Bergwall
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
