Question about Leisure Kitchen Ranges
Leisure range cooker cmce96 - fan oven has stopped working where is the fuse located
  • 399 Answers
SOURCE: hi my leisure alta cookers
ceramic plates and the fan has to be replaced as you yourself know whats the problem.
you can get the required parts at this link
www.repairclinic.com
just enter the model number of your unit and the part you require.
and if u want to do it manually you can check out this following link
http://www.applianceaid.com/micro.html
feel free for further queries.
thanks.
Posted on Sep 23, 2008
farfield
  • 462 Answers
SOURCE: having problems with fan assisted oven on leisure
Often these fan assisted type ovens have a safety that keeps th fan off if it believes the door is open. Look for uneven door closing or cracks in the door to frame closure. Is this a commercial convection oven?
Posted on May 08, 2009
  • 68 Answers
SOURCE: Problems with the oven heating up on Smeg CC92 MFX5 range cooker
instalation wiring may be criss crossed if under warranty get them out to fix it.
Posted on Oct 13, 2009
SOURCE: TECNIK 1285 RANGE COOKER
I have a Tecnik Range cooke that was in the house when i bought it. The secong oven has no cover for the heating element at the top so everything I put in browns at the top. Should this oven have a metal plate underneath so that I can use it as a conventional oven or should it be like that
Posted on Mar 30, 2010
caroldon
  • 17130 Answers
SOURCE: leisure naples range cooker ignition not working
It can be due to break in the wiring to the ignitor pods , a short in the electrode or a possible malfunction on the circuit/ trigger switch. All this requires that you need to isolate the sections one by one to confirm. detach the HT lead to the electrode and if there is high voltage check on the fittings of the electrode/insulation. If the HT is absent then check the trigger switch and circuit.
Posted on Nov 21, 2011
My gourmet classic leisure cooker has a noisy fan. What can I do?
Hello CAROL ROSA,
If it is NEW... TAKE IT BACK.
ELSE... (replace the fan).
Post the actual model number to see if
we need to look for 'parts' (USA) or "spares" (rest of the world)...
Together we can get this
'FIXED' (USA) or "sorted" (rest of the world)...
http://www.harveynorman.ie/home-appliances/cooking-appliances/range-cookers/leisure-gourmet-classic-oven-grb6cvr.html
Aug 30, 2016 | Kitchen Appliances - Others
I have a leisure range cooker. model number CMTF99R.The oven RHSis not Heating up. the fan is working and the thermostat light is coming on.
Check for voltage at the element, could be a hi-limit thermostat or a failure at the control board.... You may find you are missing one leg (half) of the 240VAC required to power the elements
Jul 31, 2016 | Leisure Range 90 CMTF95C Cream 900 mm Dual...
Where are the fuses in a Victoriana Deluxe Leisure cooker? The extractor fan and light have stopped working
It would be fused to the house current most likely through a circuit breaker on your service box.
Jul 19, 2016 | Kitchen Ranges
Main oven not no heat.thought maybe heating element. tried to take element out from inside oven but seem I may need to take back cover off as it seems the two screws on one side come in from there.
yes your doing fine, usually heating element are sturdy and seldom busted. try to follow the wiring inside and locate the thermal fuse that is installed inline with the wiring,have it replaced
Sep 03, 2015 | Leisure GRB6CVR Electric Cooker with...
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
Location of thermal fuse in leisure cookmaster range cooker
where is the thermal fuse located in a leisure cooker
Jul 22, 2010 | Ovens
Have a Leisure roma 100 cooker model number RM10FRS main fan oven not heating need a service manual to find out how to get at heating element to see if needs replacing.
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
Jul 05, 2010 | Kitchen Ranges
Having problems with fan assisted oven on leisure roma 100 cooker, it doesnt seem to work everything else seems to work fine, Can anyone help me
May 08, 2009 | Kitchen Ranges
Flavel Milano 100
Hi all...
Yep got the main oven gone......
Lucky iam good with electrics, got my brother in law to double check Qualified Elctrician it turns out that its the Thermal Fuse that has gone have ordered a new one at the cost of £8.......
This range is made by Beco thats why its hard to find info on the cooker.. The grill/fan oven has thermal fuse as well.....
Hope this helps MVE
Aug 11, 2008 | Kitchen Ranges
Kitchen Ranges Logo
50 people viewed this question
Top Leisure Kitchen Ranges Experts
Timllfixit
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
