Question about Microwave Ovens
Bosch steam oven HBC36D753B is not getting hot enough to produce steam
How do I fix e5116 on my Bosch steam combi oven
sad thing brand new items should have a service call made to the manufacturer. if you try to fix yourself it could void any warranty they gave you .
Sep 20, 2016 | Bosch Microwave Ovens
I have a Bosch steam iron TDS25, and the handle of the iron is getting red hot and water is coming out of the back of the iron. Help!!
Steam irons become clogged from water deposits. You may clean your iron with white vinegar and water. You should use distilled water. Make a Mixture of 1/2 water and 1/2 vinegar, and pour the mixture into the iron as you would when you fill the iron with water. Turn the iron on 'steam' and let the mixture run through. You may need to do this a few times, depending on how clogged the iron is. After cleaning use distilled water to fill the iron, becuase distilled water leaves minimul deposits behind.
May 01, 2014 | Microwave Ovens
My ovens turns on but fails to produce hot wave
A microwave oven produces heat with the help magnetron which produces radiation. so the magnetron need to be replaced. try to contact your oven dealer! i do suggest to have a new microwave oven. because the magnetron is costlier you cannot repair it! Main cause of magnetron malfunction is, less use of microwave oven or less voltage.
Jan 14, 2011 | Kenmore Microwave Ovens
My 7qt slow cooker glass cover doesn't have a small hole for the steam to escape, so while it's cooking it is continually lifting the cover spitting out water and dripping over the whole counter, is that...
The slow cooker works by heating the food up to around 85 degrees Celcius and should not boil. If you have it hot enough to boil place a tooth pick under the glass edge. That will let the steam out.
Jan 13, 2011 | Microwave Ovens
I have a brand new Bosch microwave model HMV8051U It was installed for 1 day and the interior glass on the door shattered. What would cause this to happen?
It could be door alignment, damaged or chipped when installed, scratched and moisture got in the scratch and turned to steam under pressure or hit with something spinning around in the machine.
Almost anything.
Take it back and get it replaced.
Jan 03, 2011 | Bosch 800 HMB80 1000 Watts Microwave Oven
Hi the plastic latch on the left hand side of door has broken off. where can I get a spare part and how easy is it to fix?
It should be straight forward enough to repair/replace.
You can buy a replacement by either an online store or go to the Bosch web site for a list of authorized dealers.
Hope that helps.
Nov 08, 2010 | Bosch HLK4525GB Convection/Microwave Oven
Pro STEAM steam press ...no steam being produced
Here is a tip that will help you to get better results from your question onFixya.
How to ask a question on FixYa
heatman101
Oct 10, 2010 | Microwave Ovens
Do not understand the use of the sensor
Dear ggold
I think you refer to the steam sensor. I,ll explain how it works with one of its uses. Say you want to reheat a plate of food. You can do this two ways. You can guess how much time it will take to warm the food, and maybe not heat it enough or overcook it which can ruin some foods. Or you can just press the "reheat" button. The oven will come on at full power and continue to operate until steam begins to rise from the plate. The oven then switches to a "countdown" mode until it determines the food is hot. Saves time and guesswork. Most modern ovens work like this. Since you dont give the make and model of your oven, this is the best I can do.
Ray...
Nov 23, 2008 | Whirlpool Microwave Ovens
Microwave
That's probably because there's still steam (humidity) in the cavity after the first bag is popped.
After the first bag pops, try wiping down the walls and ceiling and leaving the door open for a couple of minutes.
You might even blow or fan the air out of the microwave.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 02, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
