Question about Samsung SyncMaster Televison & Video
Tv antenna my tv antenna port not working
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
Probably its TDT and not RF
Posted on Oct 19, 2013
How to properly connect the channel Master antenna tuner to my TV so that I can connect an antenna to the tuner. I have the CM-7001. I'm connecting through the HDMI port on the tuner to the HDMI port
Confusing question! The CM-7001 is meant to be used for displays or monitors that have no means of connecting an antenna and don't have a built-in tuner. HDMI to HDMI would be the correct way and make sure you select the proper HDMI port. Or use the other video and audio cable connections.
Sep 03, 2014 | Channel Master CM-7001 ATSC Antenna and...
Antenna unrecognized.
Sometimes the TV will lock out other inputs when a cable is connected. Try the antenna by itself and put the TV in Channel scan mode. If this works reconnect the cable TV cable. If that doesn't work you may need an A/B switch
Feb 19, 2018 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Antenna input on back of tv broken off
if your converter box has rca output toy can hook it up that away. Or you can look on ebay for a new main board. very easy to replace. be sure at all time to unplug tv while back cover is removed.........hope this helps
Dec 01, 2013 | Sharp Televison & Video
I am plugging in a cable from the dishnet satellite in to the antenna port in back and i can't get it to work. But my other tv's work fine doing the same thing
you usually cant go directly from the dishnet sat antenna to the tv without convert (dish box) i would try put it in the cable port and run from the menu options channel scan. do tht as well with the antenna port.
Mar 22, 2011 | Vizio VW37L 37 in. LCD HDTV
Which end is the receiving end of a house tv areial
peter_321
One end of the coax cable is connected to your antenna. The other end connects to a coax port on the back of the receiver labeled "TV/Antenna Cable In". All DISH Network receivers have this port on the back except our "K" series receivers. These receivers require a module to plug into the back of the receiver. Connect the antenna cable to this port, "TV/Antenna Cable In", if the receiver has the port available. I hope this helps.
Ray Calo
DISH Network
Mar 05, 2011 | Televison & Video
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
TV Ears won't work with new Toshiba tv
wrong ports
for antenna operation you need antenna in ports
Nov 03, 2017 | Toshiba 32AV502U 31.5 in. LCD HDTV
Cannot connect the coverter box
When you have your converter box hooked directly with coax to your tv, is your antenna then plugged into your converter box in the "antenna in" port? What do you mean by it doesn't work? Does it say no signal? If so, you just need a stronger antenna. If not, you may have a defective box, bring it back to the place you got it and see if they can help.
Dec 27, 2008 | Symphonic ST420FF 20" TV
Televison & Video Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
