Question about Panasonic Audio Players & Recorders
Sb ps70 speaker
How can change laptop connecter speaker
How to change laptop connecter speaker
it is on-board u had to remove complete socket and plug the new socket
Oct 19, 2013 | Panasonic Center Speaker Sb-hc480 Home...
Creative SB X-Fi titanium rear speaker out problem
Hello.
This sound card it is well compatible and all you have to do its depending on your OS update and reset the sound properties to get the full reestored sounds of all channels.
Hope this hint helps
Carl
Apr 02, 2017 | Creative Technology Creative Labs Sb0880...
Vsx-815 sb. system
Check in your speaker setup menu. Sometimes you can select between using the surround back speaker jacks as "B" front speakers as well. You would have to tell the unit which one you want to use it as.
Feb 08, 2013 | Audio Players & Recorders
ONKYO TX-SR701 - Hi When using the speaker config I can get output from all speakers but the Surround back speaker R does not work. I do get sound from Surround back L. It's a bit confusing as the...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR701-Receivers-manual/id/365ag222/t/2/
7.1 would have Surround Back L and R.
6.1 would have just one back there (SB). It defaults to the Left output on the Pre-Outs if you ever go that route.
This being a 6.1 receiver it does not support two SB channels BUT you can configure those amp channels for a separate Zone supporting 2 speakers. Confused?
The manual shows a single SB speaker connected to the left side on Page 27. THAT would be consistent with a 6.1 configuration.
Jun 04, 2011 | Onkyo TX-SR701 Receiver
I have just bought a technics sc-dv290 hi-fi off of my cousin and found out the mid range and the tweeters have blown does anyone know where i could get replacent tweeters and mid-range speakers for it if...
As you probably know, these are the individual model numbers:
SC-DV290 the base unit
SB-DV290 speaker set
Front SB-DV290
Center SB-PC95
Surround SB-PS95
I'd scour Google or eBay for any or all of those models. Orphan speakers appear periodically.
Feb 10, 2011 | Technics SC-DV290 System
Speakers but dont know how to connecet to computer?
You need an amp to receive output from the computer. Then you connect the speakers to the amp. A computer speaker-out jack will not drive speakers -- only headphones.
May 04, 2009 | Panasonic Audio Players & Recorders
My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
May 06, 2008 | Panasonic sa-ht800V Home Theater Audio...
Help with SB-WA920 sub woofer PLEASE!!!!
Sure, you can use transition between SB-WA920 system cable with other output. So, you use them as speaker. That's it.
Sep 07, 2007 | Panasonic SC-HT920 System
19 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
