I unhook my dell hp pavilion v70s computer from
I unhook my dell hp pavilion v70s computer from hard drive box because was moving and I tried to hook back in the new house the sceen came on but power down and the button on the hard drive box never came on but there a green light came on on back of it by the power cord could please tell what's wrong
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
Try to see if the RAMS didnt shift
Posted on Oct 19, 2013
  • 3 Answers
SOURCE: Computer will not power on
Regarding the blinking green light on power supply for hp a430n...I've had that happen as well when the computer is turned off for an extended period of time. It would not immediatly power up when plugged in to power. Hitting it and beating on the button didn't help either.
However, after calming down, I noticed that when I unplugged the computer that the light continues to blink, but gradually fades and goes out. So, I thought that since power supply holds a charge after being disconnected as can other components inside a computer that I would assume the converse: It needs to power up to "full charge" as well. In my case, I was right.
All I did was plug the computer in and leave it alone for about 20 to 30 minutes, go sit and cuss for a while. When I came back and checked it after that time, the front panel blue light was on and the green light on the power supply was glowing steady. The computer started right up! Thank goodness...stopped cussing.
If it hadn't, and I had tried all the resets listed above, I would have bought a new power supply too...but not this time!
Posted on Feb 15, 2008
leecom72
  • 4806 Answers
SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
Posted on Dec 14, 2008
blueextc3221
  • 15935 Answers
SOURCE: we have an hp pavilion
Did the switch on the power supply get bumped?
There will be a toggle switch. one side has O and other side has - . It needs to be on the - to turn on.
Posted on Jan 12, 2009
lglalight
SOURCE: computer wont turn on
i had the same problem its going to be your power supply it probably burned out. when i changed mine it worked perfectly.
Posted on Jun 01, 2009
nyilasrobert
  • 627 Answers
SOURCE: I have an HP Pavilion a384x. It will not turn on
verify on the power suply is a switch with 2 positions 0 and 1
It must be positioned to 1
If not, the power supply could be damaged. It must be replaced
Posted on Aug 03, 2009
Could you show me the correct way how to power up the hard drive box a green circular light is by the power cord is on when plug up but the fan is not running could you show me what is wrong the computer...
Could you take a picture of the entire back of the PC? You only show the power supply connected with power, what about the graphics card output? and power to your monitor etc.?
Oct 19, 2013 | Computers & Internet
Hp pavilion beep
Try setting the AHCI to SATA in the BIOS.
May 10, 2012 | HP Pavilion m8020n PC Desktop
How do I transfer photos from an old HP Pavilion 6830 CPU to our new computer, a HP Pavilion a6750f?
easiest way would be to use a usb thumb drive. Better yest invest in an good external Hard drive - move all of your photo from old pc (use my computer - select folder and move) then connect the external hard drive to your new pc and "copy" to your new pc. when all done you even have a backup copy of your precious photos in external hard drive...
Oct 10, 2010 | Computers & Internet
How to transfer files from my old HP Pavilion 8650C to Dell computer or seagate external hard drive?
With the drive plugged in, open My Computer. You should see an icon labeled something or another that relates to your external hard drive. If you cannot determine which it is, unplug the hard drive. One of the icons should vanish. When you plug it back in, open the drive that appears. In order to transfer files, simply find the ones which you wish to move on your computer (most likely in the My Documents folder), then copy and paste them into the hard drive. Tell me if you have any more issues, and vote if this helped!
Oct 10, 2010 | HP Pavilion 8650C PC Desktop
HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Oct 29, 2009 | HP Pavilion DV6700T Notebook PC
HPw19 screen connected to a HP freezes
Hello this looks like you have a loos connection somewhere, check all connection,
Are they properly connected, press firmly into the sockets.
The monitor input connection can get loos.
Try with a new cable.
If nothing helps it needs to be repaired.
Aug 29, 2009 | HP Pavilion dv6000z Notebook
Dell computer will not work with an older HP monitor
no dell have set up there computers so you cant use othe appliances that arnt dell. so im sorry for the inconveince.
please rate my help to you.
thank you.
Apr 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Mouse, cursor and scrolling problems
HI TRY CHANGING DISPLAY SETTING IF YOU THING IT THE DISPLAY
Dec 03, 2008 | HP Pavilion Media Center a1330n - AMD...
Hp/sceen/hard drive/motherboard
video onbord is going bad and screen and or connection to it on hp will need whole new mobther bord from ober heating using it on bed cant **** heat from botttem out back so it overheats kills parts
Oct 06, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
