Question about Zenith ZEN400SP Remote Control
Program mbr3447 remote - Zenith ZEN400SP Remote Control
    Top Expert:
  • Zenith Master
  • 74,198 Answers
Programming procedure is too much to type in, and is not practical. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Posted on Oct 19, 2013
Is a Zenith MBR3447 Remote Control universial
Yes, Zenith MBR3447 is a universal remote control. To view the codes list, download the manual, click here.
Oct 26, 2011 | Zenith MBR3447 Remote Control
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
I am loking for three digit code for mbr 3447 to control a panasonic tv.
Full code book with instructions on how to program your MBR3447 here: http://www.replacementremotes.com/store/productdetailp.cfm?productid=61974
Apr 01, 2009 | Zenith MBR3447 Remote Control
Zenith mbr3447 code for magnavox converter box?
To download the full code list with the instructions on how to program go to link below:
http://www.replacementremotes.com/store/productdetailp.cfm?productid=61978&reset=1
if your none of the codes work for you cable box then your SOL. try programming your cable box remote for your tv instread.
Jan 15, 2009 | Zenith MBR3447 Remote Control
I want to know how to use some features on my Zenith MBR3447 remote
My guess is SURF might let you scan through the channels like a scan button on a car radio. PIP stands for picture in picture and may require a second device(vcr etc.) with a seperate tuner to use. SWAP allows you to swap pictures when useing PIP. Freeze probably will allow you to freeze the current picture on the screen.
May 14, 2008 | Zenith MBR3447 Remote Control
Remotembr3447
remote controls only sound.
power or channel select does not operate.
remote light does not come on for the TV button ????
Jan 13, 2008 | Zenith MBR3447 Remote Control
Mbr3447 remote code for samtron vcr
Up untill a few years ago they used to make a lot of universals with a "learning" function, that you aim the thing at a certain device untill it figures out the right code for it. I read that the technology was bought since so you dont see those quite as often in the market. ok, if yours is a learning uni, here's a tutorial on how to fix it, in general terms since it varies between remotes: If you cannot get the instructions - most "universal" remotes have a "code search" feature. Usually this involves hitting the "program", "select" or "function" button, then pressing the device button ("TV", "VCR", "AUX") then repeatedly pressing the "power" or "channel up" button until the set responds. The remote will cycle through each of the codes (01, 02, 03, 04) sending the "power" command for each. When you hit the right code - the set responds. When the set responds, stop and then press the "program" or "function" button to enter it (which button varies between mfgrs). If you count the number of presses - that should be the code (12 presses is "12" or "012" - or it could be 11 if the codes start at 00). If you do not have a "program" button (it might be hidden), then you may have to instead hold the function (TV, VCR, Cable) button down for a few seconds (until the light blinks). The usual manual sequence is: 0 1 2 It might also be: 0 1 2 If no program button: 0 1 2 Some remotes use a two digit code, some use three. It'll take quite a bit of trial and error without the manual. you can try getting the codes from the manufacturer, go to their site and see if you can figure anything out there... good luck
Jan 19, 2006 | Zenith MBR3447 Remote Control
Zenith ZEN400SP Remote Control Logo
14 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
