Question about Kurzweil Music
My Kurzweil Ensemble Grande Mark III no longer has sound. The unit turns on, the buttons change the LED display, but no sound comes out. For awhile prior to this (previous uses) there were a few pops and crackles when I turned the unit on. If I leave it on, every now and then it makes a sound inside like the speaker is going to pop (or something)... but no sound when I press the keys.
  • 1138 Answers
SOURCE: Roland keyboard. Extremely static-y speakers. Cuts out.
It sounds like your volume slider is dirty. Try carefully and judiciously spraying a good quality contact cleaner into the slider and working it. do not use a lot. It only takes a little. Also do not use WD40.
Posted on Apr 23, 2009
  • 4 Answers
SOURCE: Repair a Mackie SRM 450 Speaker
You probably need to replace the diaphragm. The diaphragm is located behind the back cap. Simply remove the back cap, remove the diaphragm, clean the voice coil gap with a piece of masking tape, install a new replacement diaphragm, reinstall the back cap. That it!
You can see videos on how to replace diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-c/INST/Installation+Instructions
You can buy a new Mackie SRM450 diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-cp/SRM450-DIA/DIA-Mackie/Mackie/
Posted on Jul 21, 2009
  • 1138 Answers
SOURCE: Kurzweil Mark 10 keyboard stopped working
Try the reset procedure on page 5 ( last page ) of this pdf document:http://www.dgaudiorepair.com/PDF%20Files/HARD%20RESET%20for%20Current%20KURZWEIL%20.pdf Hope this helps. Note the first procedure says highest white key. I'd do the second procedure.
Posted on Aug 29, 2009
Hugh fulton
  • 62 Answers
SOURCE: Kurzweil piano keys are clicking seems to be worn out.
I don't see you doing any damage by having a look but I would get a piano tuner or repairer in to investigate the problem expertly - no slight on you. But if your Church congregation depend on it it's well worth the money.
Good Luck
Posted on Sep 13, 2009
  • 5603 Answers
SOURCE: My Yamaha YDP-121 digital piano has a key that is
Check if it might be dragging on the edge of the case. The restoring force for some of these comes from a silicone rubber dome that is oart of the contact. SOMETIMES the dome fails.
Posted on Nov 29, 2009
Testimonial: "sounds good but i am a novice with repairs and do not really understand all the terms used. also, i am not sure how to go about fixing or getting repl"
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
Apr 14, 2016 | Kurzweil Music
Tell me some tips and tricks about using the Kurzweil sp3x stage piano
The place to get the best help for Kurzweil gear is Sweetwater Sound.
Other than that, always use it in stereo mode with a decent sound system. Always use speakers with at least a 15" woofer and a horn to get the full range of sound it's capable of.
May 18, 2014 | Kurzweil Music Systems Kurzweil SP3X...
Replacing battery in kurzweil mark 12
As per the manual it says it is located near the power switch. You will need(as per the manual instructions): a screwdriver(Phillips head), a knife, a pair of scissors, and a pair of front end wire cutters as, when shipped from the factory, the three AA batteries were taped or cable tied as a shipping precaution(to keep them from falling out). ***WARNING: MAKE 100% SURE YOU HAVE BACKED UP ALL OF YOUR SOUND PATCHES ON A FLOPPY DISK BEFORE BEGINNING THIS PROCEDURE!!! ONCE YOU START THE REPLACEMENT PROCESS, YOU HAVE ABOUT 30 SECONDS BEFORE THE BOARD LOSES ITS CHARGE AND YOUR SOUND PATCHES GET ERASED FROM THE ROM CHIP.***
Make sure you have all of the needed batteries and tools before beginning.
Hope this helps.
Nov 23, 2012 | Kurzweil Music Systems Kurzweil MARK152I...
When I turn on my Kurzweil PC2X, the LCD screen shows the message 'Scanner is dead!' followed by 'battery voltage low (0.0 volts).' The lights on the keyboard flash at me and the keyboard won't make any...
Try a factory reset.
Turn the unit on, and while the display says "Please Wait", press and release the Panic button. Press the right arrow button till the display says "Hard RESET". Press Enter, then the button under "Yes" in the display.
Sep 03, 2012 | Music
I brought my kurzweil sp 3X to a store to have them installed a new board on it, but after they installed the new board in, the character displayed on the screen are all in a weird organize and messed up....
It sounds like the new board and firmware has gone to abbreviations instead of fully spelling it out.
I would complain to the store since they should warrant it if it is a problem... but be prepared to accept that the firmware has been changed and displays differently now.
Mar 23, 2011 | Kurzweil SP3X 88-Key Stage Piano
My kurzweil micro piano will come on and the lights are on but theres no sound,even the demo will not play.the unit is plugged in correctly.i have not used it for several years.
Just make sure you are not sending out a midi volume from your keyboard, this could turn the volume down or off. I am not sure what else could cause this. hope it helps.
Apr 19, 2010 | Music
Original circa 1982 Kurzweil Ensemble Grand upright, has been working just fine until today. At first the (grand piano) sound had just become very distorted or seemed to have messed up sustain or echoing....
Given its age, this unit needs a little TLC. Units of that vintage used some capacitors that may have dried out a bit and need to be replaced. There are also op-amp ICs internally that may be defective. I would suggest a visit to a service shop that works on keyboards as not all do.
Keep us posted.
Dan
Dec 08, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Aug 27, 2009 | Music
Music Logo
811 people viewed this question
Top Kurzweil Music Experts
drivealot
john cordey
john cordey
rhodesworks
Are you a Kurzweil Music Expert? Answer questions, earn points and help others
