Question about Smeg Ovens
My brand new oven wont turn on, its model is a SA561X-9
Aeg ovens work on brand new model number 49176iw-mn but induction hob wont turn on
Many people have had faulty AEG cookers. I would return it if i were you and get something else
Jun 24, 2016 | AEG Ovens
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Just bought brand new oven and the fan cones on but wont heat up. I have set the clock as the instructions say this has to be done before the bottom fan assisted oven will work.
Contact the store where you purchased it, it should be under warranty. They may be able to help you on the phone. They will know the brand etc.
Oct 31, 2015 | Ovens
Oven wont turn on reads F-9
Check the door latch
Mar 24, 2013 | Jenn-Air Ovens
Oven won't turn on, had a power outage on the street 3 times today. Tried flipping the fuse, but nothing has happened. Any suggestions? Not sure which model Zanussi it is, except it is not brand new!!
The electronic clock/timer must be in manual mode for the oven to operate. When the power to the oven is cut the electronic clock/timer reverts to automatic mode when the power comes back on.
Mar 07, 2011 | Zanussi ZBS963X Electric Single Oven
Amana oven model ACF4225AC the big oven power ...
have and Amana oven/stove model ACF4225AC that is 8 yrs old. Middle glass (thick tempered) part # 32028101 completely shattered. Oven was not on for at least a week, noone was near it,was not hit,and at 9 AM while I was in other room it just shattered into a million pieces. Went to dealer- looked up part and found it was no longer available. I have been checking internet appliance part companies, and e-bay to no avail. Cannot find replacement glass. Any suggestions? Thanks, Jim
May 21, 2010 | Ovens
Stove is brand new. turned oven on for 30 minutes for initial burn, open door, but it won't shut completly, why?
You don't provide a make or model number, but if it's new, look in the Owner Manual for door malfunctions. Call the store where you bought it and tell them of the problem.
Dec 18, 2009 | Ovens
Oven doesn't work!!!
If you will let us know what brand and model number this unit is, we will attempt to resolve your appliance repair issue.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service.
We answer our customers calls from 7 AM until
9 PM CST so call us when you are ready for us to get this oven working properly for you.
Thanks, Ella
Nov 11, 2009 | Ovens
I have a 8 month new elect built-in oven, model 790, Kenmore. The door wont open and giving a F-9 fault indications on the control panel display. Tried everything to get it to unlatch so i could open the...
should still be under warranty- contact your kenmore repair center or dealer where you purchased it. might be a failed safety interlock switch.
good luck! hope you sent in your warranty reg. card, or still have your receipt! if you have your owners manual, it may have a list of fault codes, and what they mean, and possibly explain how you can clear them! when in doubt- try unplugging it and plugging it back in- carefully! you're dealing with 220V! turn it off first!
Sep 24, 2009 | Kenmore 30169 Electric Single Oven
Bake element in smaller oven replacement
I always unplug oven or turn off power make sure though it will bite ya and hard after turning power off if you do it at the breaker turn stove top on make sure it don come on remember its 220volts and it hurts open oven door remove all racks.Then remove the screws mounting element to oven pull gently towards you (you may have to lift the front up a little) pull old element out until you see the spade connector (plug ins with the wires attached) remove these should be two of them be careful not to let wires go back into the cabinet put new element in hook wires back up to wires push back into the hole and put screws in turn power back on and test. this can also be done by taking the back off also and doing the same thing in the oven.hope this helps ya
good luck
Dec 07, 2007 | Ovens
Ovens Logo
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
