Question about Konica Minolta bizhub Office Equipment & Supplies
Error code c2162 konica minolta c351 - bizhub Konica Minolta Office Equipment & Supplies
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
  • 51 Answers
SOURCE: Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
Posted on Aug 30, 2009
  • 158 Answers
SOURCE: Malfunction Detected C-0206 on Konica Minolta C351
this error code means that tray 3 paper could not lift up to the feed rollers. open the tray and check the paper tray and checkthat the paper is loaded correctly pull all the paper out of the tray and check to see if any is folded or crumpled if the paper is ok it could be the lift motor has failed or the main boardPF or main boardMC or the dc power supply needs to be replaced.
to reset the code leave the machine on and open then close the front door
Posted on Nov 17, 2009
  • 44 Answers
SOURCE: how do we change the language on the konica minolta bizhub c351
1) Press "Utility-User Setting-Language Selection
2) Go to service mode System 1 - Marketing Area - US
You have to do both
Posted on Nov 29, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0206
C0206
Tray 3 feeder up/down
abnormality
• The tray 3 upper limit sensor is not blocked
even after the lapse of a given period of time
after the lifting motion has been started.
Jul 15, 2014 | Konica Minolta bizhub C351 All-In-One...
C dc00 konica minolta c351
CDCXX-trouble related to security.Try to reset:
Turn OFF the copier.Press and keep pressed the Utility key and turn ON the copier.Keep pressed the utility key and wait to Trouble reset message appaire on the display.(1-2 minutes.).Release the utility key and touch the message.Turn OFF the copier,wait 1 minutes and turn ON.If the error code displayed call the technical rep. from Konica Minolta.
Apr 06, 2013 | Konica Minolta bizhub C351 All-In-One...
Error cod c-d204
Hi
Try disconnecting the printer from power completely and then reconnect again.
Mar 03, 2012 | Konica Minolta bizhub C450P Laser Printer
My konica minolta bizhub 361 has an error code c-2801.... what does that mean?
In my experience you have to change the developer and the machine will be ok.Also there is a chance that you have to clean the two toner sensor that are located in the end of the toner bottle,sometimes there is the problem.please let me know.
Aug 16, 2011 | Konica Minolta bizhub C351 All-In-One...
I have a konica minolta bizhub c351 How do I
select "PDF"- MMH option, not the "MMR" option from one touch menu.......
May 15, 2010 | Konica Minolta bizhub C351 All-In-One...
check in one touch setting, PDF-MMH and MMr, multiple files and single file option, if having problem then call your tech service rep
Mar 29, 2010 | Konica Minolta bizhub C351 All-In-One...
Error code C-0211 Konica Minolta Bizhub
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} C0211 :Bypass Lifting Motor Failure
Nov 10, 2009 | Konica Minolta bizhub C351 All-In-One...
adjustment.
Change PWB-C.
Aug 03, 2009 | Konica Minolta bizhub C351 All-In-One...
64 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
