Question about ESA EF402E 20" TV
I found game mode turned it on then off, Now I want to turn it on but I wouldnt work. Everytime I press picture it goes on sharpness.
Default scene
Hi Brenda,
Press the Mode button and press Up or Down arrow key till you find SCN and press OK
Press up or down arrow key and choose Potrait and press OK.
Come out of the menu and everytime you wanna take a picture, it will be in Potrait mode.
Regards,
Suhail
May 20, 2012 | Kodak Easyshare M580 Digital Camera
I can not program my AT&T remote control to control my SHarp DVD BluRay BD-HP20. I have tried the easy find feature and every Sharp code I have found on the internet and the AT&T website for Sharp...
Hi!
You may try these codes: 1311, 3163, 1312, 3164, 3176, 2174 and 3177
If none of these codes work try the steps bellow:
Programming with the Automatic Code Finder
The automatic code finder cycles through all possible codes for the type of equipment you are programming until the correct code has been found.
  1. To program your remote control with the automatic code finder feature make sure that the Sharp AQUOS Blu-ray Disc Player is ON.
  2. To control your disk player: With the equipment on, PRESS AND HOLD DOWN, the AUX Mode Key on the remote control. The mode keys are located across the top of the AT&T U-verse remote control. While holding down the AUX Mode Key, press and release the OK button. If done correctly the Mode Keys will blink twice. The remote is now ready to be programmed.
  3. The next step is to enter the code for the automatic code finder feature. That code is 922. Enter the code 922 using the Remote Control's keypad. You have 10 seconds to enter this code before the remote times out. When 10 seconds have elapsed the Mode Keys will flash once. If this happens just start over.
  4. The next step is start the automatic code finder search. Make sure you aim your remote control at the equipment. Then press and release the play button on the remote control. Now press the Fast Forward key multiple times until the equipment turns off. Then press Enter to save the code. Your remote now has the correct code. If done successfully the Mode buttons will flash three times. Press the Power button again to turn on the Disk Player.
  5. When the code has been entered correctly, the appropriate Mode Key will flash three times. To check to see if this code works, press the Power button. If the Disk Player does not turn off, then the code is wrong and we need to try another code.
Keep me posted for clarifications.
Thanks.
Lor04
Apr 06, 2011 | Sharp AQUOS Blu-ray Disc Player
My playstation 3 : everytime i turn it on it goes green then back to red and wont turn on? When it was working it just froze so i turned it off and since then it hasnt turned back on
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning .
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
Everytime I turn on mu playstation 3, no picture comes out in TV.
Try accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 2-5.
Try using HDMI cables and AV cables.
Jan 16, 2011 | Sony Playstation 3 (PS3) Console
After pressing the audio button on my psp the screen would go black and white from bottom to top then would go back to normal what i tried is to take out the memory card and tr to press the audio...
Hi, I've had the same problems for about a month now. I have a psp fat (psp-1000) with cfw. 5.50. I was playing ZHP unlosing ranger when the same thing happened.
I use the lowest brightness setting to lengthen game play time. I keep using the audio button (The one you hold and turns the sounds mute or back.. right?) for the game then when i reset my game (press home and start the gameover..) the brightness suddenly keeps on changing even making the whole screen black. After 5 minutes? it stops but then when i press the down or square, triangle button the brightness changes sometimes thats the only thing the button does.. i found a temporary fix for this, i put it sleep mode then turn it on again and it stops.. the buttons go back to normal, for a while.
It goes on and on even with other games. It just stops after 10 minutes later or more than starts happening again everytime the brightness or audio button is pressed.
We scanned it for viruses on a computer and it just kept on blinking everytime it responded to the scan. No virus were found but after that when we disconnected it from the computer the brightness problem stopped for a good long time.. we avoided pressing the brightness and audio buttons. but recently its happening again.
and now just got worse. I was playing Socom Fireteam, and when you accidentaly go to the start menu, you have to press "select" to exit and continue the game. But the "select" button wont work!
so i quit the game and startover.. when this happened for the 3rd time. When i pressed "home" button and was asked if i really wanted to exit the game i couldnt move to "yes" and couldnt press the "O" or "X" buttons.
So i turned off my psp and when it went back on, I couldnt press anything anymore. except, the volume buttons and select (the vsh menu appears)
I searched for help from the internet, found "disable your vsh menu" remedy.
It worked! but when i played the game, the "cwcheat" menu keeps on appearing (seplugin that appears when you press select button). It wouldnt stop >.<
So we disabled that too.
Now playing God of War Ghost of Sparta, and one part, the start menu kept on appearing! we'd close it so that we could push one of the levers in the game but then it pauses the game again.. it stopped after a while. then it happened again only slight.
Found a comment on a "select button problem" and it said that it was the:
"parts that were Ribbon style, with it was the start and select button and the volume/sound" he had that parts?
found same problems around the net, some posts from 2009.
found decent posts and solutions here:
http://forums.qj.net/psp-general-help/151111-psp-slim-start-button-stuck.html
the best one says buy a new "flex bar" or "home bar". It goes by many names, but it's the metal bar that has all of the bottom row buttons on it (home -> start) It's usually under $10 USD and obviously the right thing to do.
got another comment that says it worked from him when he bought one himself.
Glad I found others, and that I could share this.. wish it makes things better.
Hope it works out for all of us!
Another thing, Merry Christmas!
Dec 02, 2010 | Video Game Consoles & Games
Do you know how to reset the drum counter for Sharp Al-1641
Reset the drum count by pressing "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode"
Exposure mode is far left key on panel. You need to do this fairly quickly so that the display goes blank.
Once display goes blank then key in 24 then press print, then key in 7 then press print. You should now be getting flashing 000
Turn machine off then on and light should be gone.
Short version: C,far left,C,far left,24,print,7,print
Dec 30, 2009 | Sharp AL-1641CS Laser Digital Copier
My samsung blue flip cell phone, everytime I press 369 or#....
If you notice the 3,6,9, and # are all on the same column. There is probably some corrosion under the keypad from a spill or moisture. If cleaning the membrane switches won't work try replacing the keypad (the electronic portion, not the rubber). Repost if you need instructions. I can put some parts up on ebay for you too.
Aug 17, 2009 | Samsung Cell Phones
Sony Ericsson K530i won't turn on again.
i have problem on k610i....it cant be turn on the red light only turning on..there is no display..
May 26, 2009 | Sony Ericsson K530i Cellular Phone
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Everytime I try to take a picture my cam turns off
That happens to me once in a while...Just when I feel like throwing in the towel, it starts working again! But I am actually having a problem right now: Even with fully charged batteries, the camera goes into "low battery" mode when I turn it on, and right now I can't download some really important pics...ARGGGHHHHHH!!!!!!
Nov 07, 2006 | Fuji FinePix A400 Digital Camera
ESA EF402E 20" TV Logo
Top ESA Televison & Video Experts
Demonic-2011
Demonic-2011
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
