Question about Samsung LN46A650 46 in. LCD HDTV
I HAVE SAMSUNG 40" LED LA40D503F7R AND IT SHOWS SOME LINES ON THE SCREEN AND SOMETIMES IT DISAPPEARS AND THEN COMES BACK. WHAT MIGHT BE THE PROBLEM PLEASE SUGGEST. THANKS IN ADVANCE.
techman
  • 3130 Answers
SOURCE: Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
Posted on Aug 06, 2006
ripleymojica
  • 643 Answers
SOURCE: I dropped my Samsung LN-T4053H 40 in. LCD
yes. sorry to deliver bad news. cost to repair is 90% the cost of when you purchased. panel is around 400-500 plus your labor. samsung may have flat rate program but still is not very economical. sorry again.
Posted on Jun 04, 2009
AndroidLVR
  • 31 Answers
SOURCE: green lines down length of screen on my samsung 40 inch LE40F8
The reason for the green lines are the resolution. I'm assuming you're TV is set at 1080i, not 720p or 1080p correct? What happens is the "i" stands for interlaced, meaning, your TV displays your images with scan-lines. The "p" stands for progressive, meaning, TV displays picture as a whole. You can not visibly see the scan lines when seeing 1080i, but certain TV programs are not outputting their show to the resolution you're at, which will cause you to have the green line up at the top of your TV. SOME TVs might let you adjust the settings to rid yourself of the scanline, but most consumer TVs will not let you without the maintenance code to protect your unit from over calibrating and braking your television. Hope this helps.
Posted on Mar 20, 2010
budmrtn
  • 11361 Answers
SOURCE: I have a 40" Samsung
Look for bad caps with domed tops in the power supply module first, it may have dying power supply.
Boards and prices: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-T4061F+
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Feb 01, 2011
budmrtn
  • 11361 Answers
SOURCE: I had Samsung LCD Series, 530 Model LN52A530 52"
Does it look like this?
http://s807.photobucket.com/albums/yy352/budm/Samsung%20LN-T3242H/
If you tap on the main board, it may come back on.
Posted on Feb 04, 2011
Samsung 5271f. Picture usually great but sometimes when an image with horizontal lines appears (e.g. crawl at the bottom of the screen) picture jumps and flickers. Reverts back after crawl disappears.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 12, 2017 | Samsung Televison & Video
How to fix a led tv that has vertical lines around 5 minutes after turning it on then disappears when the tv has warmed up?
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 28, 2016 | Samsung Televison & Video
I cant play movies using my USB drive on my Samsung LCD tv model LA40D503F7R. Movies option on screen is not displaying, only music and pictures option is displaying
Nope, you certainly can't. The TV can only show still photos or play music. It's not capable of playing videos.
The manual is here:
http://www.samsung.com/ae/support/model/LA40D503F7RXZN
or
2011 LA40D503F7R 40 Inch Full HD LCD TV LA40D503F7RXZN Support SAMSUNG Gulf
See pages 16 and 17.
Burn your movies to DVD or Blu-Ray and you can plug a player into the TV, also described in the manual.
Oct 02, 2015 | Samsung Televison & Video
I AM UNABLE TO CONNECT USB ON MY SAMSUNG LCD TV MODEL NO.LA40D503F7R
you need to switch the input to USB from antenna or cable probably
Sep 14, 2015 | Samsung LA40D503F7R 40 Full HD 1080P...
I have horizontal lines on the top 6 inches only all of the other picture is fine.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 14, 2015 | Samsung 40 LN40D630 LCD TV
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
I want schematic for bn44-00469b
Hi. Just google and you will get it. https://www.google.com/search?q=schematic+for+bn44-00469b&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwifxt2kla_QAhXIOI8KHVb3AcgQsAQIGw&biw=1280&bih
Mar 02, 2014 | Samsung LA40D503F7R 40 Full HD 1080P...
I have samsung plasma la40d503f7r the problem is
What is the problem you faces with this TV? Provide more details please. If you wish to get some details, check this site linked here.
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 14, 2013 | Sony Samsung LA40D503F7R 40" Full HD 1080P...
Gateway 400SD4 Power Problem
Faulty Battery.
Get a new one.
If that is not the problem check the ram.
Jul 01, 2008 | Gateway 400SD4 Notebook
Samsung LN46A650 46 in. LCD HDTV Logo
172 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
