Question about Google Nexus 7 16GB, 2013
Brand new nexus 7 2013 missing 2 navigation bar buttons( menu + recent app)
Where can I find bsic instructions for the moto g 5 plus? I can't find the menu bar or the one step navigation.
Consumer Cellular has a manual for the Moto G5 Plus here: https://www.consumercellular.com/assets/documents/Manuals/Moto%20G5%20Plus%20User%20Guide.pdf . The menu bar is usually hidden; the icon can vary. Press the icon with several horizontal lines or a vertical line of dots inside the app; you should see the options, including help. Not all Motorola devices support one button navigation with the fingerprint sensor. If your device does, you need to enable the feature. Open the Moto app, select Actions and then One button navigation. Enable the feature.
I hope this helps.
Jun 23, 2017 | The Computers & Internet
Tip
First-Class SWF Converter for Google Nexus One,Convert SWF to Nexus One Speaking...
Speaking of Google Nexus One, we will immediately say it is Google's flagship smartphone manufactured by Taiwan's HTC Corporation. It became available on January 5, 2010 and uses the Android open source mobile operating system. As a multimedia-enabled smartphone, Nexus One is capable of playing videos encoded by H.263 (encode and decode), MPEG-4 SP (encode and decode), H.264 AVC (decode), audio formats including AAC, MP3, MIDI and WAV.
Personally, I bought a brand-new Nexus One when it initially launched on the mobile market, because of its 3.7 inch wide touchscreen, 5 megapixel camera and its long battery life. I am a movie fans and I always pay much attention to the newly-released movies such as Avatar, Transformers 3, District 9, and etc. So I often need a Blu-ray Ripper or Video Converter to convert these movies to my Nexus One for enjoying when traveling. Recently, I got a bunch of SWF files from my boss and wanna merge and convert these files to my Nexus One for playback. By searching the keywords "SWF to Android Converter" through Google, I got a fabulous SWF to Nexus One Converter. With it, I import SWF to Google Nexus One (.mp4) with success.
The Detailed Tutorial I use is as below:
To begin with, free download Aunsoft SWF Converter and install it on your PC.
Second, import SWF files to this program and specify the output format workable to Nexus One.
Expand the drop-down menu of Profile, locate and choose Android -> Google Nexus One MPEG-4 (.mp4).
By the way, you may notice the button "Settings", this button is used to set the video and audio parameters, including Codec, Bitrate, Frame rate and Channels. As Nexus One can play movies up to 800x480 pixels, under this option, you can set video codec to mpeg4 or xvid. You can set frame size to 800x480, 480 x320 and 720 x480.
Next, if you want to join SWF files into one, you are allowed to check the box "Merge into One to file" on the main interface.
Fourth, specify the destination folder by using "Export To" as you wish.
Last, after the settings above are done, it is time to start the SWF conversion to Nexus One for your entertainment yourself or with your families.
on Jul 17, 2010 | Cameras
How can I download a new Play Store app to asus tablet nexus 7 android? The Play Store app that I try to go on my tablet, turns off when I go in it!
Go to settings>Apps/Application Manager>Select ALL>select Downloads/Download Manager>click enable.
Clear the recent apps and then restart.
HTH
PS: to avoid giving credit card details, purchase a Google Play gift card and use that instead.
Dec 10, 2014 | Nexus 70mm Real Silent Case Fan Case...
I don't know how to take photos on my nexus 7
The Nexus 7 does not come with a built in camera app. I guess Google figures since there is only a front-facing camera that folks won't be taking too many photos.
I recently came across an app on Google play that will allow you to launch the camera to easily take photos. You can find the Camera Launcher App for Nexus 7 on Google Play.
https://play.google.com/store/apps/details?id=com.modaco.cameralauncher&hl=en
Apr 03, 2013 | Tablets & eReaders
How to delete games from nexus one?
From home screen... Hit the Menu button... Choose Settings... Choose Applications... Choose Manage applications... Click the tab called All... Select the app that you want to uninstall... select "Uninstall".:-)
Jun 08, 2011 | Google nexus one
My android market hasnt updated yet
A common fix for a common problem- clear Market application's data: 1. Navigate to your phone's "Settings" via menu button.
2. Scroll down to "Applications" and select it.
3. Next, select "Manage applications."
4. Now, select the "All" tab
5. Scroll to find "Market" and select it.
6. You may now select "Clear data" to reset the Market application to it's original state.
Navigate to the Market app to launch it. Wait a minute or a few depending on the number of applications installed. Update notification should appear in navigation bar prompting you to update your market applications.
Apr 06, 2011 | Motorola Mobility Backflip Smartphone
How to delecte recent logs
These steps should be more or less similar.
  • Press the OK button for Menu
  • Select Recent Calls, using the navigation keys
  • Select All (4)
  • Select the Recent Call type, using the navigation keys, from the following:
  • Missed Calls
  • Received Calls
  • Dialed Calls
  • All Calls
  • Highlight desired Recent Call, using the navigation keys
  • Press the right soft for Options
  • Select either Erase (2) or Erase All (4), using the navigation keys
  • Highlight Yes, using the navigation keys
  • Press the OK button to confirm call log deletion
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 22, 2011 | Samsung SGH-T309 Cellular Phone
My address bar, refresh button, back and forward arrows etc. have disappeared. Why has this happened and how do I get them back?
You are missing your navigation toolbar. Hopefully you still have the menu bar where it say's, "File Edit, View etc." Move your mouse up to the View tab and left click that tab. That menu should open. Slide down to toolbar and items like Menu Bar, Navigation Toolbar should have check marks beside them. You probably don't have a check mark next to Navigation Toolbar so, left click that location. Upon completion of last instructions the address bar, refresh and back and forward should all reappear.
Dec 18, 2010 | Mozilla Firefox
How do i restore my web address box & the back button & also the 'File' 'Edit' buttons on my Mozilla Firefox??
The Firefox "menu bar" includes dropdown menus for various tasks (including "File", "Edit", etc.). If the menu bar does not display, press the "Alt" key (if you are using Windows). That will restore the menu bar temporarily. To restore it permanently, go to the menu bar and select:
View > Toolbars > Menu bar
The Firefox "navigation toolbar" includes the "back", "forward", "reload" buttons, and the address bar (where you type a web address). If the navigation bar does not display, go to the menu bar and select:
View > Toolabars > Navigation toolbar
See screenshot:
Dec 15, 2010 | Mozilla Firefox
My mozilla firefox window no longer shows menu or navigation bars. How restore?
Hi pbqsf
The Menu bar and the navigation toolbar have been disabled. You can enable it by following the steps below:
1) Open firefox
2) Press the 'Alt' key on keyboard (Pressing this button temporarily brings back the Menu bar)
3) When the Menu bar shows up, right click on an empty area right next to Help as shown in the picture
4) Now select the Menu bar option and the Navigation toolbar.
Now, your Menu bar and Navigation toolbar will be up.
Thank you for using Fixya.
Nov 20, 2010 | Computers & Internet
Google Nexus 7 16GB, 2013 Logo
49 people viewed this question
Top Google Electronics - Others Experts
Are you a Google Electronics - Other Expert? Answer questions, earn points and help others
