Question about Craftsman 358797290
Correct way that carb. kit parts [gaskets,diaphram] are installed on craftsman 24cc gas leaf blower?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
The side with the Gas regulator ( round metal disk in middle of diaphragm) Gasket on carburetor then that disc diaphragm then cover plate.
The other side that has the diaphragm with the cutouts go on different. That cutout thing ( Reeds) go up against the carburetor then the gasket then the cover.
Posted on Dec 29, 2013
SOURCE: won't start --has gas--has spark craftsman leaf bower
i have a crafstman blower 358794770 wont start i replaced the sprak plug gas lines and the carb it gets sprak but don't get gas in the cylinder.what's left to do?
Posted on Sep 03, 2012
SOURCE: craftsman leaf blower/vacuum
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
Posted on Apr 24, 2009
#1 Taper
  • 1040 Answers
SOURCE: craftsman blower won't start( 24cc 2-cycle)
You may need to do two more additional things.
First, check the fuel lines for cracks/breaks.
If they are o.k.,then you will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Usea Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit abd replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Posted on Jun 13, 2009
SOURCE: craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Posted on Aug 21, 2009
Dolfoff
  • 148 Answers
SOURCE: how to rebuild craftsman leaf blower carburetors
If it is a ZAMA carb look here.
If it is a Walbro carb look here.
Hope this helps!
Posted on Sep 28, 2009
Pour gas in carb. will run few sec. replaced both gas lines and filter.
You will need to clean the carb or if this unit has a walbro carb buy a rebuild kit and it will work just fine.. Good Luck...
Mar 23, 2011 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Craftsman 25cc 2-Cycle Blower/Vac only runs with choke on
Your engine is starving for fuel. Tyipically rebuilding the carb is a quick fix. If you can remove the carb and look at the face of it, you should see a brand and model #. Use this to purchase a carb kit with the needle and metering diaphram or have a mechanic rebuild the carb.
Oct 05, 2010 | Craftsman Garden
Redmax blower older model does not start, tried a few drops of gas in spark plug port and it started. but stalls after fuel in burned off, any help would be appreciated, djk913
Carb. problems sounds mostly like the carb needs to be thoroughly cleaned out, drop fuel bowl and hit openings with a tiny steel wire and carb cleaner also check the diaphram, sounds like its cracked/dried up.
Aug 02, 2010 | Homelite 'Yard Broom' Leaf Blower
Poulan wt200 won't start replaced all diaphrams spark ok cleaned gas filter
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. (THIS IS KEY!) Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 01, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan gas weedeater wont rev up
you seem to have carbarator problems you can take it apart and clean it and it should work
Sep 17, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Craftman leaf blower when I press primer bulb I get air in line. It seems to be coming from block that choke is attached to hoses look good.
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Aug 05, 2009 | Craftsman Blower Attachment
Craftsman blower won't start( 24cc 2-cycle)
Jim
Jun 12, 2009 | Craftsman 4 Cycle Blower/Vac
No Gas to Primer Bulb
It sounds like the carburetor needs cleaned. Take the carb. apart and clean it with carb. cleaner. Use a Den Tech Brush, (used for cleaning teeth), they are perfect for cleaning the small ports in carb. If that still doesn't work, you may need to buy a carb. kit for your weed eater. If so, replace the gaskets and valve needle, and also make sure to replace the small screen. this should all come in the new carb. kit.
May 21, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Parts number
You need to know if it is a walbro or a zama carb. to start with.
then look closely at the carb. and find #`s
very small
walbro will be wt or wa then some #`s
zama will be c1q or c1u and some #`s on the opposite side of carb.
Walbro will be on the same side
you need to know the carb. #`s so a kit can be found for that particular carb. IE: complete kit or diaphram kit
May 20, 2009 | Homelite Consumer Products MightyLite...
Craftsman 358797290 Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
