Sony ta kmsw500
How does the control cable work. ie the cable between the amp and this unit that switches the unit on. The socket seems to be faulty and I would like to short it out so that it is permanently on??
jango2
  • 38 Answers
SOURCE: Distorted sound
Are you a technician capable of internal repair? This seems like a case of either positive or negative supply rail to right channel blown. Probably an open fuse or open series supply line resistor.
Internal view of amp here;
http://www.tarad.com/_tarad/_modules/view_image.php?picname=p6033619n3.jpg
The round orange doughnut shaped device at the left is the unit's toroidal transformer. To the right of it are these 2 legged upright, white rectangular ceramic resistors. They are typically low value with a power of approximately 5 watts. A quick cold test with an ohm meter might reveal one of them to be open.
Switch off and unplug unit before opening. Be wary of charge retained in the big fat electrolytic capacitors in the centre.
I do not suspect a case of blown output transistors since the relay does not go into protect and sound is audible but distortyed in one channel.
Safe !
Jango
Posted on Mar 03, 2008
VOTIT
  • 2071 Answers
SOURCE: find a user manual for a Sony TA-VE150 Amp
Just click below for electronics site download;
http://servicemanuals.vstore.ca/
http://www.eserviceinfo.com
Hope it may help you;
Regards,
VOTIT
Posted on Jan 07, 2009
SOURCE: Sony TA-AV421 Amp
im needing help connecting my audissey aps 5+2 energy floor speakers . im confused on the 2 channels
Posted on Apr 07, 2009
SOURCE: HOW TO WIRE AN EQUALIZER TO A SONY TA-FE370 AMP
You can't wire an equalizer to this amp unless you only want to equalize one source, because it doesn't have a tape monitor function.
Posted on Aug 01, 2009
  • 174 Answers
SOURCE: Sony TA-AX335
yes , after so long time this tapedecks are old equipments if you wanna make them to go first you have to recheck the cables and replace them. and see what it does
Posted on Apr 17, 2012
I AM TRYINGTO CONNECT MY SONY AMP, MODEL # ta-n731 to my sony model# ta-e731
https://docs.sony.com/release/TAN731.PDF
Looks like you need some rca cables to connect the outputs from the e731 to the inputs of the n731. There is also a small 4-pin control cable that connects the units. It probably tells the amp when the pre-amp is on. You may be able to do that manually if you can't find the cable. Or you may be able to make your own cable if you can identify the connectors.
Mar 08, 2015 | Sony Audio Players & Recorders
Hi, my sony ta-fe370 has stopped working. All fuses seem fine and there is no obvious visual problems inside. The red led next to the power button comes on but then goes out again. The source selection...
What power are you meaning that Also, all of the other decks connected to this also have lost power Is this mains power If so check the power on the switch
Oct 12, 2013 | Sony TA-FE370 2-Channel Amplifier
Amp not switching on, totally dead. ta - kmsw500
First check for line voltage, check your fuses, then you can go from there
Oct 02, 2013 | Audio Players & Recorders
Wires connect stereo
Assuming that your TV has a headphone socket, the easiest way is to connect a lead from the headphone socket on your TV to a spare line (or auxiliary) input on the Sony amp. You will need a 3.5mm stereo plug to twin RCA plug cable, long enough to reach both pieces of equipment. Most electrical stores should have a suitable cable available at modest cost :o)
Aug 19, 2013 | Sony TA-FE370 2-Channel Amplifier
Trying to set up just the amp & tapedeck of the Sony TA-AX335 integrated stereo system, but can't get the ribbon power cord to work.
Does the deck light-up at all, or is it completely dead? I've found that in aging tape decks, the belts will deteriorate, and change into tar. I've repaired several of the TA series Sony systems, and that's usually the case. If the deck is just 'dead,' I would recommend retrofitting standard RCA jacks on the back of the amplifier. The pins on the ribbon cable are clearly marked on the PC board inside the amp. Then, you could use any deck you want, or even a CD recorder. Hope this helps. :)
Apr 13, 2013 | Audio Players & Recorders
I have an old Sony LBT D505 (with a SONY TA D505 amp) its abundled system but for some reason it automatically sets source to tuner and i cant change source. I have checked the system control cables and...
it must be due to a bad connection if the cables are fine it may be the connectors or where they solder on to the amp or radio board if the amp with out the radio cables attached still will only select tuner its the amp fault, even worse i could be a faulty integrated circuit eg faulty micro chip good luck with finding a replacement
Jul 04, 2011 | Sony Audio Players & Recorders
Tuning my toshiba tv to hdmi
You don't need to tune it to HDMI. Connect the HDMI cable to the rear HDMI socket & then select the HDMI source from the remote control, this will switch the TV to this input & show whatever the picture is from that source ie DVD/Cable etc.
Aug 27, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Jan 22, 2009 | Sony TA-FE370 2-Channel Amplifier
Sony TA-540E TWIN DRIVE AMPLIFIER
Hi Jimbob. Sounds like you have dirty/dry controls/switches. The contact lubricant dries out on them producing intermittent and scratchiness when you operate them. Clean any offending controls or signal switches with CRC2-26 by squirting(to flood then internals) each control/switch. you will have to do this from the inside of the amp. You may also have a dirty speaker protection relay, sound may return to a dead channel when you turn the vol up points to that. Good Luck. If you need more info feel free to get back to me here. Happy to talk you through more if you cant sort it out.
regards
Graeme
Mar 22, 2008 | Sony TA-FE370 2-Channel Amplifier
Sony TA-AX301 Amp looses left speakers
many times this problem is the result of dust and or dirt that has collected in your control pots.ie.volume,balance etc....the solution is usually to take the amp apart to get to the pots and clean them out with tuners cleaner or some such product...a quick fix would be to rapidly move the knobs side to side or press the buttons or toggle the switches as fast as you can in hopes of clearing some of the particles from the affected area...
Feb 03, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
