Cannot record simultaneously on two channels any more
  • jukka kautto
    jukka kautto Oct 20, 2013
    My LG RH7521W DVD is equipped with twin tuners. Recording two channels simultaneously worked well five years, but some months ago just one channel at a time could be used. It is not a reception problem, because I have another gadget that works perfectly on two channels and picks four programs simultaneously. Is it only of my digital homelessness that I am missing just a simple setting fix or is it a hw trouble and task for an authorized repairer.
Recording problem
1. Press and hold down the ASSIGN A button (the light should be blinking) then (simultaneously) press the REC button above channel number 1. The light should blink when you do this.
2. Release the ASSIGN A and the REC button
3. Press the REC button above channel 1 (the light should be blinking by itself)
4. You should see the meters moving with in the display above Input A and Track 1 when you speak into the microphone.
5. Press the REWIND button twice until the display reads ABS 00.00.00.00
6. Press and hold the RECORD button and press the PLAY button. The REC light above channel one, the PLAY light and the RECORD light should become solid.
7. After recording press the STOP button.
8. Press the REWIND button twice until the display reads ABS 00.00.00.00
9. Press the PLAY button.
Apr 16, 2014 | Tascam DP 008 Digital Portastudio
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
Unable to watch separate channel when recording another on LG RHT497H. Question is can you watch another channel when recording another?
I scanned the entire manual for your recorder and found no mention of simultaneous dvr functions as you specified, so I have no choice but to say no you cannot...sorry...
Aug 27, 2012 | LG RHT497H Digital TV Recorder with 160GB...
We just dvrs hooked up a few weeks ago.when I am recording somthing down and my daughter goes upstairs to watch her tv and tries to change her channel to watch somthing a message comes up on the tv that...
Hi, poog_23350, I caught your post! How a Duo DVR receiver works is that the TV you have it set to record on will not allow you to change the channel while the recording is in progress. The other TV, that isn't recording anything, can be used freely to flip through channels.
In this case, it's TV2, the one upstairs in your daughter's room, that's currently set to record on while the downstairs TV is free to use. This can be adjusted by pulling up the Main Menu with the Menu button on the remote, selecting option 8, then option 5, and changing the TV1/TV2 setting there on the Record Plus screen.
If you'd like a receiver capable of allowing channel changing while recording a program, our VIP 612 receiver is a Solo receiver that acts like a Duo. What this means is that it has one TV output and two tuners. Along with being able to change channels while a recording is in progress with this type of receiver, you can also record two programs on two different channels simultaneously.
Hope that helps!
Aug 29, 2011 | DISH Network DVR-625 DTV Receiver /...
How do I use 2 mics for the XL2 simultaneously?
Hi, on the left side of the camera you can set 'audio monitor'. Default is channel 1/2. You can choose to listen to 3/4 or 1/2 and 3/4 simultaneous.
In the menu of the cam you can set between 12 bit audio recording or 16 bit. 16 bit only records on channel 1/2 (the front mic). In 12 bit mode you can record audio on 4 channels.
hope this answers a bit of your question
Mar 17, 2009 | Canon XL2 Mini DV Digital Camcorder
Playing dvd's
could be a ratings problem. Perform a reset by holding down your channel up and channel down buttons on the unit itself simultaneously until it shuts off. Wait a few seconds and turn it back on. Give it a try. Good Luck - Tamara
Oct 14, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
I bought dvd hdd recorder 3 days ago from lidl it is a targa DRH-5700X seriel no. e5809000859. Imust not have it connected right as i cannot get anything from it on the television.Ihave the recorder...
i have a targa 5500x from lidl cant copy from hard drive to dvd as i have done this many times but the dvd drawer keeps opening telling me to put in blank dvd and i keep doing this but getting no where,
mary
Apr 23, 2008 | Toshiba SD-4000
Cable hookup and av hookup
Connect your TV to AV1 and you SAT/Cable Decoder to AV2.
on the video select the AV2 channel and it will record whatever is connected to AV2. The AV channel selected it is the input the one not selected is the output.
Some PPV Movie channels are copy protected with some service providers. But most channels are recordable.
The aerial lead coming in your house connects to the SAT/Cable Decoder 1st, then connect the output socket on that to the Video/DVD then the output on that to the TV. As long as the leads you use have different ends on you CANNOT plug them into the wrong socket. As the the aerial passes through each device, the device adds its own RF channel to the feed, so you should be able to tune both a SAT/Cable and a Video/DVD channel onto the TV set aside from using AV/Scart.
Dec 27, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Simultaneously Recording and viewing different TV programs
Just leave the vcr on the channel u wanna record! and press TV/VCR on the remote, (only if it's over the air) antenna, not cable or satelite! you would need 2 boxes for that!
Oct 13, 2007 | Samsung DVD-V4600 DVD Player/VCR
Recording
Does it record when you are simultaneously watching a program? if yes, then recording circuits are OK. It is definitely a problem of settings. Try doing it again step by step. And before you program for timer recording, make sure that the VCR clock is set for correct time.
Apr 07, 2007 | Sanyo VWM-900 VHS VCR
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
