Question about Dishwashers
Instruction manual bosch sgu53e75au
Where is the location of the inlet water valve on Bosch dishwasher model SGU53E75AU ? Thanks for your help.
bigg t
  • 640 Answers
SOURCE: Dishwasher tub slowly fills with water after after completion
the internal parts of the valve are sticking open randomley.the diaphram/piston in the valve most likley have lime deposits on it due to poor water quality.you would need the water valve assembly but before you buy this part i would look where the water line goes into the dishwasher and it will lead you to the valve.remove the valve from the unit and disassemble the valve.clean all the internal parts in the valve and reinstall.75% of the time this works ,if not change the valve.
Posted on Jan 24, 2008
  • 1462 Answers
SOURCE: My Bosch dishwasher model #SHU43C05UC/14
open machine when running and check both spray arms rotating - you will get a bit of water out. if spray arms not rotating, usual cause is debris in the arms. the spray arms only rotate by water jetting from angled jets at the end of the arms. take them out and make sure all debris removed
Posted on Jul 14, 2008
  • 27 Answers
SOURCE: Bosch SRS4302GB Replacement Inlet hose - which type?
it should have and is delivered with the narrow bore high pressure hose
if your water flow rate is high more than 20 ltrs p min you could get away with a standard low preessure hose
you can download the instruction manual from the bosch web site or from the bsh home appliances web site
good luck
Posted on Mar 12, 2009
SOURCE: Bosch SHU 4000 series dishwasher; Water keeps on filling
Follow-up: I was able to fix the problem on Bosch model # SHU 4002UC. Purchased water inlet valve (part number 425458) from Sears Parts Center. I required the Sears unit number from the original invoice as Sears computer system apparently cannot identify the Bosch model number. The valve is as described by meyerjr above; however it is located at the bottom front of the machine so could be replaced (not so easily) without removing the machine. Cost of part was $30.50 Cdn including tax.
lwou
Posted on Apr 20, 2009
SOURCE: Bosch Exxcel Dishwasher operating instructions
What dose E15 mean
Posted on Mar 08, 2011
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
How do I run a self diagnostic on Bosch Classic Electronic SGU53E75AU/86?
Before going to the controller it might be better to verify the heater or thermostat (NTC).
If you want to know the part details refer this schematic
http://www.bosch-home.co.uk/store/spareparts/Builtunderdishwasher/SGU53E75AU/86
It is interactive and you can switch between assembly drawings and parts lists. The heater and thermostat are drawing 4.
Apr 26, 2014 | Bosch Dishwashers
My Bosch works very well.But when you idol it for several days, there will be a lot of water, if you don't clean up,soon or late got overflowed
If the dishwasher is filling to overflow level when not in use, you need to replace the water inlet valve/solenoid assembly. The valve is not closing fully allowing water to seep into the washer.
If you have a check valve for the water supply to the dishwasher, I'd suggest closing the check valve while the washer is not in use until the inlet valve has been replaced. If you don't have a check valve, if you leave the power switched on, the washer will automatically pump out when it reaches overflow level. The anti-flood protection system will stop the dishwasher overflowing as long as the power is on. Closing the check valve is by far the best option!
The inlet valve/solenoid is located behind the toe-kick below the door and is relatively easy to replace yourself. The only tools required are a Torx T20 screwdriver for removing the toe-kick and the valve.
If you are confident that you can undertake this repair yourself and have the tools, I've listed the part/supplier details and fitting instructions below. If you would prefer to call a service technician, make sure you aren't charged more than $30-35 and no more than an hour for labor.
Please note: This part relates to the Bosch SHX45M05UC/xx. If you do not have this model, verify the correct part number for your model before ordering.
Part number: 607335
Description: Water inlet valve (sometimes called water inlet or valve access)
This part is used on all versions of SHX45M05UC/xx, so it doesn't matter if the 'xx' on your model is 01, 02, 06, 12, etc.
Suppliers:
Bosch - $28.10 plus shipping (in stock)
http://www.bosch-eshop.com/eshop/bosch/us/prodls.htm?Matnr=000000000000607335&ESHOPTYPE=A
Sears Parts Direct - $24.49 + shipping (on backorder)
http://www.searspartsdirect.com/partsdirect/part-number/Bosch-Parts/Dishwasher-Parts/607335/0022/630/Model-SHX45M05UC48/1794/0130000?keySuffixId=NA&productTypeId=x&searchModelNumber=SHX45M05UC48
There is an option on this page to check part availability at local stores.
Appliance Part Pros - $29.21 + shipping (in stock)
http://www.appliancepartspros.com/part_details.aspx?part_id=4070550&pn_=607335
(APP use their own part numbering. This part is listed as AP4070550)
Fitting instructions:
1. Switch off the power at the breaker and close the water supply check valve
2. Clear as much water from the sump as possible - a turkey baster works well for this
3. Remove the two Torx T20 screws from the toe-kick then tilt the toe kick out to remove it
4. Remove the base insulation (if fitted)
5. Disconnect the water supply line from the inlet valve
6. Make sure the sump inlet hose is clear of the inlet valve
7. Disconnect the wires from the water valve - make note of where to re-attach first!
8. Remove the two Torx T20 screws from the inlet valve
9. Pull out the inlet valve and disconnect the hose
A small amount of water will drain from the hose when you disconnect it (assuming you drained the sump first) so have something ready to catch the water if possible.
That's it. Refitting is the exact reverse of the above. This is a relatively simple repair, but it's a good idea to take digital photos as you go along so you can refer back to them when re-fitting parts.
Hope this helps. If you have any questions or need assistance should you decide to replace the valve yourself, please let me know.
Regards,
BElectric
Apr 29, 2011 | Bosch Integra 500 SHX45M05UC Stainless...
My bosch dishwasher is not filling up with water. Where is the inlet filter?
Welcome to FixYa.
Based on your description, " my bosch dishwasher is not filling up with water. Where is the inlet filter? "... and to answer your question, the issue is likely with the inlet/water valve.
**To remedy this you will need to replace the valve, not surprising for Bosch unfortunately**
This is what to look for..i.e.
As long as your model number is indeed SHU8805 series, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in you should be good to go.
Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Nov 24, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Letter F appears on screen, and dishwasher does not start. Sounds like pump runs for a bit then stops. Door is closed. What is wrong?.
Hi
Error code F indicates that dishwasher control has detected a fault with dishwasher filling. This is due to faulty water inlet valve. Please check for clogged water inlet valve. Water inlet valve part#35
You can buy it from this link---
Bosch SHU531 water inlet valve
Hope this helps... Please post back if you need more information
Daniel
Nov 10, 2010 | Bosch SHU5315UC Dishwasher
Not getting water into machine although mains water is reaching hose intake. model number of bosch is sgs44e28eu05 type si1501b
There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. thanks.
Feb 17, 2010 | Bosch Dishwashers
good luck
Mar 06, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
The inlet valve will be at the dishwasher end of the (hot) water inlet line. On this dishwasher I ~believe~ the inlet valve is near the rear of the unit. That means that you will need to pull the dishwasher out to get to it. Remove power from the dishwasher as soon as you can before messing with the unit.
Just past the connection of the supply hose and the connection on the dishwasher, there will be the valve (a solenoid valve with two wires coming out of it.) That is the little beast that has most likely failed.
Good Luck!
Jan 14, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I HAVE NO INSTRUCTION MANUAL -WHAT DOES CODE f17 MEAN PLEASE
F17 code refers to "low water pressure"...check the water inlet valve.
Dec 23, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch Dishwasher SHU9922
It is the inlet valve, some are located inside the appliance, some mounted in the back panel. Occationaly some have the valve at the end of the hose in a box. The price for repair the first one cheapest the last most expensive. regards Appliance Doctor
Feb 02, 2007 | Bosch SHU9922UC Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
