Question about Health & Beauty
Rascal can i run 36 volt on rascall scooter to make it go better
  • 103 Answers
SOURCE: I AM ONLY GETTING 9.3 VOLT TO THE MOTOR
Just to be sure have the batteries tested with a load tester. Then ohm test the brake. It should be around 35 ohms.
Posted on Mar 09, 2009
gewiz
  • 1263 Answers
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
Posted on Jun 13, 2009
  • 61 Answers
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Posted on Mar 19, 2010
  • 2418 Answers
SOURCE: I HAVE A RASCAL MOBILITY
I do not know of a Scooter graveyard, but I will look for one. I found a site that sells many different types of 24volt battery chargers. If you have a special port on the scooter and you still have your old charger you can cut off the end of the bad charger and wire it onto a new battery charger. Now as with most lead/acid battery's any charger with a built in volt/amp regulator will work.Your old charger spect's are for a 4amp max rating, Any constant 2.5amp or better should recharge your battery's overnight. I am sending you a link to a site called Battery Stuff.com where you can find a 24volt charger for as low as $89.oo, Now I understand this may be a bit out of your range, but a new battery charger for a laptop computer will run about $115.oo. So for a Heavy Duty scooter that is not to bad. Plus it may out last 2 sets of battery's. Now use this site as a reference and maybe you can find one you like local. Hope this helps Fixya up.
Posted on Apr 12, 2011
gopakumarg43
  • 74136 Answers
SOURCE: Rascal 240 scooter Battery charged ,scooter
Hello
There is an overload protection switch in it. It will look like the the protection switch that can be seen under the mixes. The picture of the overload protector is added here. Its press button will only seen outside. Just putsh it once and check. The motor has carbon brushes inside it to get armeture contact. If these burshes are worn out, the motor won't turn, and the scooter won't move. There will be two of them in opposite directions. They are replacable parts. The picture of it is also given here. Check these first. If you need anymore assistance from me, feel free to get me by FixYa.
gopakumarg43.gifgopakumarg43_0.gif\
OK
Posted on Aug 05, 2011
Does the owners manual have a wiring diagram in it for the rascal 230 electric scootetr
Hi marilyn, Sadly no mobility scooter manual will give you such information, i willing to help , what do you want to know ? faulty lights , thinking of fitting a new controller ?
Regards
Rob
Feb 15, 2016 | Electric Health & Beauty
I need a. Wording diagram for my rascal 200 mobility scooter. Where can I find one downloadable?
go google --type in schematic diagram for rascal 200 mobility scooter and if there is one you will see it as a pdf version download
Sep 11, 2015 | Health & Beauty
What type of batteries does this model take?.jb.
you need 12v 33ah sealed deep cycle battery most likely it may need two batteries any thing above 33 amp hours would also be ok. A higher Ah the longer the batteries last. This information on the type of battery is from the user manual.
http://www.hardwarexpress.co.uk/rascal-388-mobility-scooter-battery-1949-p.asp
Any battery type store should be able to supply this to you .
Feb 10, 2015 | Electric Mobility Rascal Scooter...
Does anyone have arepair manual for a rascal 300 I need to fix the electromagnetic brake
It is the same as a Rascal 600 only the 300 has smaller wheels.
The manual is not much help on the brake, it does not go into repairing the bake, except for checking voltages and replacing the microswitch, some tips are a little oil on the detent balls help to keep it free and movable, but don't get oil on the brake pad.
Scooter Doctor App
Aug 27, 2014 | Rascal 300 Electric Scooter - Used...
Wiring schematic rascal 600 24v electric
hi, firstly what controller is fitted (curtis) ? then i can give you a ideal controller wiring schematic but you won't get hold of a Rascal one..
Regards
Rob
www.gewizrepairs.co.uk
Aug 16, 2014 | Rascal 600 T Electric Scooter w Seat Lift...
Rascal 600T Scooter FIX IT Manual
There is an owners manual available which has a troubleshooting guide at the following: http://manuals.monsterscooterparts.com/mobility/Rascal/manual-rascal-600-t.pdf
If you have a good relationship with a local dealer they may be able to copy and provide you with one.
Electric Mobility, the manufacturer, in my experience will not provide one to you.
Mar 02, 2014 | Electric Mobility 3 Wheel Motorized...
Rascal 600 wiering diagram
Hi Carol, I have lots of Rascal answers at my link, also check the Rasca pics, the is a Diagram there. but if you have a specific problem you can post there or here, we will do are best for an answer. Scooter Doctor App
Mar 18, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
How to make rascal 600 scooter fsater 5 mp.
in order to get it to go faster, you could put larger wheels on it, or get an OEM programmer to adjust the speed. They did not want to be sued so they did not make them available. any of the higher speed scooters have hand brakes. There probably is a market to sell ways to speed up Rascals, but I can not except the liability. sorry Scooter Doctor App
Feb 12, 2013 | Electric Mobility Rascal Scooter...
Health & Beauty Logo
18 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
