Question about Marantz SR-5200 Receiver
Manual sr5200 - Marantz SR-5200 Receiver
Marantz SR5200 Turns on and off by itself
Thermal cutoff is operating. There is excessive heat being generated on the heat sinks of the Amp. This happens when there is a shorted output transistor or a speaker load changing.
Nov 09, 2017 | Marantz Audio Players & Recorders
MARANTZ sr5200 Left Speaker larger sound right speaker
If you are saying that the left side is LOUDER than the right it could be DC offset on the recording or it could be phasing issues.
Feb 15, 2017 | Marantz Audio Players & Recorders
I have a phsssst noise in the rear left channel of my Marantz SR5200 AV Amp which occurs when I turn amp on. You can also hear it on some music. It sounds like a connection problem but have checked cables.
Check the routing of the cables to make sure they avoid power sources and magnetic fields.
I have a buzzing sound when I use my track lights which have a fader, so I avoid using them while listening.
Feb 27, 2011 | Audio Players & Recorders
My marantz sr5200 dont reproduce dobly digital signals , maybe junt 2 channels.
I have the Marantz SR5200, unable to get the Set-up / t.tone button to work, don't have the instructions,
Mar 19, 2010 | Marantz SR-5200 Receiver
No sound out of speakers (Marantz SR5200 receiver)
sounds like you might need to open it up and check the speaker wires that you plug your speakers up to it might be lose or something else like that cause it happened to me before and that was it.
Feb 21, 2009 | Marantz SR-5200 Receiver
Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Feb 11, 2009 | Marantz SR-5200 Receiver
SR-5200 owners manual
http://www.retrevo.com/s/Marantz-SR5200-Receivers-review-manual/id/511dj791/t/1-2/
Jun 26, 2008 | Marantz SR-5200 Receiver
Marantz SR5200 - front speakers not working unless direct
If you try and unplug it at least 12 to 24 hours and it does the same thing, then its time to take it in to the shop.
Aug 26, 2006 | Marantz SR-5200 Receiver
Marantz SR-5200 Receiver Logo
16 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
