Question about Fisher SLIM-1500 CD Shelf System
Fisher Slim- 1800
I set the clock, THANKS(I don't have the manual). And this model have a lot of buttons: Surewake, sleep, wake and the timer on/ off that I want to know how to set them. Thanks a lot in advance
  • Anonymous Dec 30, 2007
    wake timer- press mode/clock until the timer on indiactor in display flashes
    set clock as instructed above.
    press mode/clock again for timer off.
    set clock as instucted above.
With the unit turned off press memory once and the hour digits flash.
Press the cd ship |<< or >>| buttons to adjust the hour.
Press memory again and the minute digits flash
Press the cd ship |<< or >>| buttons to adjust the minutes
press memory once more. the display stops flashing and the clock has been set.
Posted on Dec 30, 2007
SOURCE:
After shutting down the Vostro 200 slim tower the power button turns from blue to amber and stays that way. I have to push the power button down for a few seconds to fully shut down. any idea why it does...
IT IS SLEEP MODE AND YOU HAVENT SET ANY DEVICES TO WAKE IT UP.JUST FIGURE OUT HOWE TO SET DEVICES TO WAKE FROM SLEEP OR CHANGE SLEEP TO ANOTHER SETTING .JUST GOOGLE IT AND YOU WILL FIND THE ANSWER YOU ARE LOOKING FOR.
Jun 27, 2012 | Dell Vostro 200 Desktop Computer
Unit does not turn on or display time
do you mean a power surge, if so the surge may have overloaded the elctronics,=cooked ,so afraid is u/s
Jul 07, 2010 | Fisher SLIM-3010 Shelf System
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
GE CD/clock model # 7-4901A
I LOST MY MANUAL AND I CAN/T SET TIME/DATE/AND OTHER FEATURES
Aug 12, 2008 | GE Audio Players & Recorders
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Snooze alarm
Like everyone else here I have accidentally hit the NAP button and couldn't turn it off. This morning at 2am I accidentally hit it with my husband in bed. I decided one and for all to guide this out. By flashlight and my cell phone i Googled a solution. I came across many, none of which worked. I resorted to trying methods that were posted for other models of this brand of clocks. The solution that I found that worked was to hold down the back part of the NAP button until the seat the time displayed and the nap light off. By back part of the button I mean hold down the tiny section closest to the rear of the clock. I got this solution from instructions for model RP3721A clock. It took me 17 minutes.That's just 3 minutes before the alarm would have gone off.
Nov 01, 2007 | RCA RP5440 Clock Radio
How do you set the wake up? So the radio turns on automatically? each morning
I did not find my manual, but this worked for me. Set the clock to be a 24 hour clock by pressing and holding the Memory/Clock Adj button. The display will show 24h or 12h. Use the fast forward button to change from 12h to 24h. Press the Memory/Clock Adj button again and use the fast or reverse forward buttons to change the time to read, for example, 13:00 instead of 1:00 if the time is 1pm. Press the Memory/Clock Adj button again to set the minutes.When you are done setting the time, press and hold the Timer/Sleep button. Either a time or "0:00" will appear in the display with the word "TIMER" flashing above it. Quickly press and hold the Memory/Clock Adj button until the first digit in the time starts flashing. Set the hour that you wish the alarm to sound using the fast or reverse forward buttons, just like you do for setting the time. Press the Memory/Clock Adj button again to set the minutes, and one more time to finish. The word "TIMER" will stop flashing and go solid, and the display will return to the time of day. When the alarm sounds, you can hit Snooze which will give you 5 more minutes, or you can turn the Clock Radio off. Pressing the Timer/Sleep button again will turn off the timer (alarm) and pressing and holding it again after that will turn it back on.
May 28, 2007 | Teac LT-1 Clock Radio
Clock
First - turn off stereo(standby mode) To set "timer" start and stop times, simply press the "Mode/Remain" button until the Timer's "On" or "Off" is selected. Then proceed to the following instructions. To set clock, press "Memory" then "CD - Tuner - Skip" arrows to set hours. Press "Memory" again to set minutes, and again to finish.
Mar 28, 2007 | Fisher SLIM-1500 CD Shelf System
Fisher SLIM-1500 CD Shelf System Logo
448 people viewed this question
Top Fisher Audio Players & Recorders Experts
Kardoc
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
