Question about Cell Phones
Bluetooth Not Working
Bluetooth is offline and doesn'turn on
Undo working offline
turn off working offline. on your browser (IE) click FILE the uncheck WORK OFFLINE.
Mar 27, 2014 | Toshiba Satellite Computers & Internet
Turn working offline
when you have Clicked on Work Offline then your IE is OFFLINE but after that you have to click on Work Offline then the Work Offline is Deselected then by default you have become online.
Jan 21, 2014 | Computers & Internet
Wifi is grayed out
Turn off Bluetooth in settings and then tap wifi turn off then back on. Wifi should now be working
Jun 21, 2013 | Computers & Internet
ASUS USB BT211 Not Working
https://www.asus.com/Networking/USBBT211_Mini_Bluetooth_Dongle/HelpDesk_Download/
Remove the BT211 module. Install the drivers that can be downloaded from the link above. Shut down the computer. Plug in BT211 and turn on machine. The unit should be recognized and drives put in place to make everything work for you.
Semper Fi,
Z
Apr 28, 2017 | ASUS N73SV PC Notebook
Fn f5 dosent work
Does your laptop have a Bluetooth card installed? Just because it shows on the keyboard doesn't mean its fitted.
Jul 08, 2012 | Computers & Internet
My N70 is in offline mode, i tried to repair it but it doesn't work. what can i do?
1 remove battery2 when the phones asks if continue in offline mode " click noyour phones should work perfect if not contact me back
Jan 01, 2012 | Nokia N70 Cellular Phone
My hp 900 inkjet is offline and doesn't want to feed paper.
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
try this:
http://printers.iyogi.com/hp/hp-printer-offline-error.html
Hope this helps you.
Jun 23, 2011 | HP PSC 1610 All-In-One InkJet Printer
My plantronics Pro bluetooth was working well until last night when I had to reset my IPhone. Now the bluetooth is not working. It appears as if it is not compatible. I tried my son's Iphone who did not...
Please bear in mind that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Make sure the phone doesn't have any bluetooth interference loaded on. On the link below for the Plantronics Voyager Pro look at "Listen to the Voice" for turning the headset on and off to reset for pairing and follow the pairing instructions in the manual.
Plantronics Voyager Pro+ User's Guide
Good luck from Headsets Direct!
Nov 11, 2010 | Plantronics Voyager PRO Bluetooth Headset
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
