Cannot mute honestech dvr 2.5 while recording
When I record programme from the tv it always cuts of at least one or two minutes before the end of the programme is there any way to fix this
Try setting the time of your DVR to be precise. If the recording starts 2 minutes before the show starts it will cut off 2 minutes before the show ends! My DVR has functions that allow me to add a minute or two before or after the times set to record, but that can cause other problems like if you are recording 2 shows and you try to record a new show after a show that was being recorded, it won't allow you to, because it can only record 2 shows at a time! Best bet is tro synchronize your watch to the Internet time and use that to sync your DVR time.
Dec 03, 2015 | Televison & Video
How do you make it work in windows7
I found this on a forum....I hope it helps!
This review is from: VHS To DVD 4.0 Deluxe [OLD VERSION] (CD-ROM)
I needed a way to connect my PS3 to my PC so I can take some screenshots and I only had 2 days to do this so I searched Amazon for VHS to DVD's and this was the one the best rated products. Next I went to Honestech to make sure Honestech VHS to DVD 4.0 Deluxe was compatible with Windows 7, and it was. So I rushed down to my local Fry's Electronics to pick one up, price was about the same so no problem there.
Problem:
Once everything was installed hardware/software/drivers, I ran the Honestech software and after a few minutes of running my PC just locks up. So I rebooted and tried again, but again my PC locked up, now I am confused since they said it was Windows 7 compatible and I did get the latest software from Honestech site. I first thought it was my PC but after some testing I did discover that it was Honestech software that was locking up my PC.
Solution:
OK so here is what I did to make it all work, forget the Honestech software you don't need it. Go to Honestech site and get the drivers for "HT VIDBOX NW03" this is what comes with the Honestech VHS to DVD 4.0 Deluxe. Download and install the drivers and restart, go into Device Manager and make sure you are not getting any device conflict and that everything is installed right. On Windows 7 the only thing I saw that Windows 7 didn't have drivers for was the audio, so installing these drivers fixed that problem. Now Google Virtualdub, it's a free video editing tool, Open Virtualdub go to File and select Capture AVI. Now under Device go select your USB2.0 VIDBOX NW03 (DirectShow), you should now see video coming from your HT VIDBOX NW03 go to File and select Set Capture File, enter the file name you want your video file to be and where you want to save it and hit save. Now go to Capture and hit Capture Video to start recording, and it Capture Video again to stop recording, that's it you are done.
Jan 02, 2015 | Televison & Video
Cant record two programmes at once
Well no matter the DVR, you should be able to record 2 programs at once...but you CANNOT watch a 3rd live while they are recording...also, if your DVR is hooked up to more than one tv and someone is watching something else in the other room, it will not record 2 at once, either. You can watch RECORDED programming while 2 others are recording, but not live tv.
You might want to check how many "inputs" your DVR has...most have 2 which allows the double recording...if you have an older DVR maybe you only can do one at a time. On my DISH box, they call these "TV1" and "TV2".
Hope this helps.
May 14, 2011 | Televison & Video
My dvr will not record. We moved the location of the tv and may not have hooked everything back up correctly. I have 2 tvs on this receiver and it will not record on 1 or 2.
dvr's record from the signal input, not from the tv. tv's are just used to display.i expect the input from ariel? sat dish? freeview box? is not connected right
Jan 25, 2010 | DISH Network DVR-625 DTV Receiver /...
Want 2 record from my DVR 2 Magnavox DVD Recordable/VCR MWR 2046
should have avi scrat out at back of DVR place scrat lead here and the other end into avi scrat input on your DVD recordable & feed to screen as normal.
if no scrat scoket avaible you can get a converter to switch from one to other.See your local dealer.
And happy days of u go.
Aug 07, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How to record from DVR on Centrios EDW8020 Digital recorder
am new I dont have the manual I need to know how to record I bought the dvr+r disc but its not doing any thing
Mar 12, 2009 | Centrios EDW8020 DVD Recorder
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Feb 01, 2008 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
