Question about Whirlpool GEW9250 Electric Dryer
What timer motor do I need to replace my whirlpool AWD60A timer
3 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: whirlpool dryer awd60a
Check on the link below for customer support
http://www.whirlpool.com/owners-center/owners-center-homepage.content.html
Posted on Dec 10, 2011
  • 26 Answers
SOURCE: whirlpool dryer awd60a manual
Hi
Click the following link to download the whirpool dryer awd60a manual.
I hope this helps.
The selector knob on my Whirlpool LER4634JQ1 does not move, so the dryer will not turn off automatically and no "end of cycle" buzzer sounds. Do I simply replace the timer?
Your timer most likely does need to be replaced. The timer has a small motor that causes it to rotate during the cycle and those can go bad causing the timer to not advance. Unfortunately, you cannot get just that timer motor anymore. Hope this helps!
Feb 16, 2015 | Whirlpool Dryers
Whirlpool dryer awd60a manual
Hi
I hope this helps.
Dec 10, 2011 | Whirlpool GEW9250 Electric Dryer
Machine fills with water (hot or cold) but doesnt advance whatsoever
the timer motor that advances the timer to change the cycles is not running,they are a small high impedance motor and burn out,you need to just buy a whole new timer rather than try to replace this small motor
Jan 09, 2011 | Whirlpool LSR5132PQ Top Load Washer
Hello, I have a jacuzzi jet tub and the motor will not run. We have replaced the timer and the circuit breaker as there was no power coming to the timer. The motor will still not run. There is no sound at...
what you need to do is a series of tests to narrow down the problem. first place to start is with the motor. Pull the motor out and see if it will come on when you apply power to it. If it will not start when you put power to it then the motor is not good and will need to be replaced.
Jan 07, 2011 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Wirlpool AWD60A 6KG dryer and it doesnt dry clothes
clogged dryer venting run 1 load w/the venting removed to confirm
Apr 13, 2010 | Dryers
Whirlpool commercial washer stopped running mid
Most likely the pump is plugged with lint, pillow stuffing, a small object, or some other obstruction which is not allowing the motor to turn.
Oct 29, 2009 | Whirlpool Washing Machines
I have dryer whirlpool mod. LER4634EQ2, all time is on, don't stop, the timer don't run
The timer will almost certainly be the problem. Very possible the timer drive motor is faulty. Spares for whirlpool are difficult enough to obtain, so i would suggest a new timer as it would be easier to get than a timer motor.Very easy to replace as the timer is normally modulated. (pull wiring plugs out then simply push back in onto new timer).
Sep 28, 2009 | Dryers
Whirlpool Washer Won't Drain
Did you replace the timer motor? The little motor attached to the timer that moves it thru the cycles. Also, I would check to see if the water level switch might be stopping it after the wash/rinse cycle. I've attached a URL that will show you the various components. If you need more help, feel free to post.
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Washing-Machine-Parts/Whirlpool-Parts-LLC7244BZ0.cfm
Nov 08, 2008 | Washing Machines
Whirlpool dishwasher - how do i remove timer ??
When I looked up a Whirlpool 2000 dishwasher, it shows an electronic timer. For a mechanical timer, see last paragraph.
First, turn off the breaker for the dishwasher. Then you'll need to remove the Phillips screws around the inside of the door. The inner door panel lifts up, leaving the electronics in place. Disconnect the vent motor and the dispenser motor wires. Place something heavy on the outer panel to keep it down and prop up the inner panel. Remove the plastic cover over the timer - it should pop off. Remove the wires to the circuit board. The electronics are held on with one or two screws.
Mechanical timer: Turn the timer **** backwards. It should come off along with the pointer. This should reveal a 1/4 in ***** holding the timer in place.
Mar 11, 2008 | Dishwashers
Whirlpool GEW9250 Electric Dryer Logo
22 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
