Xerox photocopier u9 error in 5016 - Office Equipment & Supplies
checkitright
  • 1362 Answers
SOURCE: xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Posted on Aug 11, 2008
  • 62 Answers
SOURCE: Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Posted on Dec 01, 2008
  • 990 Answers
SOURCE: xerox u9-5 code on a 5028 copier
Hello sir; There is a reset procedure require;
hold down 0 while you turn on the power, then enter 20 press start enter 3 press start. turn power off and on.
Posted on Aug 19, 2009
  • 239 Answers
SOURCE: i have a xerox 5016 copier ,
On this model, yes it can be the fuser thermistor, fuser relay, driver board, main board, especially the fuser fan turning very slow not up to speed.
Any of these combination can be a problem.
Also, there can be bad fuser rod connections that can cause this type of problems, and can only be repaired by a Xerox Service Representative.
Posted on Oct 16, 2009
  • 239 Answers
On this model sometimes the plugs on the connectors go bad.
They arc and will not connect good. Sometimes the ends have to be clipped and new pins male and female have to be crimped back on, replacing them on the machine part wiring connectors and fuser rod ends. this fuser kit is a part that is availiable at xerox.
A bad thermistor can cause this type of problem. If the machine overheats, the fuser triac pack can cause over heat problems as well.
On overheats the fuser fuse needs to be replaced. Do not replace with nothing else but a Xerox fuse, this is a safety device. Very important.
Otherwise place a service call to have this area repaired by xerox.
Posted on Oct 26, 2009
Xerox 5016 error code u70
Error U7, U7-1 (Photoreceptor Belt Drive)
Appears when the Copy Cartridge has Not Been Replaced.
Apr 27, 2011 | Xerox Office Equipment & Supplies
I have Xerox 5016 model Photocopier , I am getting Error U4 ,some technican from Xerox advised that it can be solved by pressing some button ..? If anyone can support would be a great help.
Enter into the diagnostic mode.Press 50 then green button,press 20 then green button,press 00 then green button.Switch off the machine & Switch On.
Jan 15, 2011 | Office Equipment & Supplies
Xerox 5016 copier error j6
error no.j6 asking how to swallow prablam
Dec 27, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
What is error U9?
This error has been detected with the power
supply cooling fan. Do the following steps :
Turn off the printer
wait 15 seconds
Then turn on the printer.
If the problem persists, check the support links at
www.xerox.com/officeprinting/1235support.
Regards
Ashly
Feb 03, 2010 | Xerox Phaser 7300DN Laser Printer
WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Feb 07, 2009 | Xerox WorkCentre Pro 423 Copier
Rank xerox 5328 U9
Nov 03, 2008 | Xerox 5830 Copier
Xerox 5328 copier error
U9-3
U9-4
U9-5
Aug 09, 2008 | Office Equipment & Supplies
k24674
