Question about Bruder MAN TGA Container Service Truck
Edc 00637-03 - Bruder MAN TGA Container Service Truck
What is edc 03779
The fault cods EDC 03779,03778 have overlapping causes consist leakage of injectors,valve ,pipe but in some time malfunction in the high pressure pump , any one agree with me or there is any addition causes.
03779.....EDC ............ Rail pressure: Leakage in quantity compensation
03778.....EDC ...................Rail pressure: Leakage in overrun conditions
May 12, 2016 | Cars & Trucks
My truck the light EDC its on how to fix
EDC is for electronic diesel control , which i expect you knew , so i would get the OBD codes read to pinpoint the sensor/switch causing the issue , can't be more exact as you faile to mention vehicle make etc
Apr 03, 2015 | Cars & Trucks
Edc 03779 what's prombelm this
The fault cods EDC 03779,03778 have overlapping causes consist leakage of injectors,valve ,pipe but in some time malfunction in the high pressure pump , any one agree with me or there is any addition causes. some people have solve the problem with changing the fuel filter.
May 10, 2014 | Cars & Trucks
EDC diagnostic 03779-10-
Rail pressure: Leakage in quantity compensation. Check the fuel rail for leakage.
Mar 30, 2014 | Bruder MAN TGA Container Service Truck
I HAVE A 33-400 TGA,EDC AND FFR GOT STOLEN.WE GOT A FFR AND EDC FROM ANOTHER 400 BUT TRUCK REFUSES TO START.WHAT CAN WE DO.
your EDC and FFR is it came from a same truck ? If no, you got to get a new FFR. If yes, try to replace a high pressure pump
Jan 14, 2013 | Bruder MAN TGA Container Service Truck
I have a problem with my Man Truck TGA 33.360, Its showing alot of error codes on dashboard EDC 00959-01, EDC 00960-01, EDC 00961-01, EDC 00962-01. What could be the problem?
I have an answer for you.The codes are coming from a lost Tachometer memory.Yoour Edc Control Unit and teh Tachometer are not correctly aligned.You need to have th Tachometer reprogrammed.It has lost memory
1.EDC:00959-01 >seconds-Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
2. EDC:00960-01>minutes- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
3. EDC:00961-01>hour- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
4. EDC:00962-01>Day- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
5. EDC:00963-01>Month- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
6. EDC:00964-01>Year- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
Nov 15, 2012 | Bruder MAN TGA Container Service Truck
Problems Man cod 03089-05 EDC
EDC 03089 -05
EDC = Electronic Diesel Control
03089 = Charge air temprture sensor
05 short circuit to earth
Mar 27, 2011 | Bruder MAN TGA Container Service Truck
Frigidaire cplef398ccb Flashing F7
version 1 of your unit F7 error code.
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
This does not mean that this is the problem but it is where I would start. EDC is less than a fouth the cost of the EOC.
Please take the time to rate this solution
Thanks,
clarkco
Feb 01, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Bruder MAN TGA  Container Service Truck Logo
305 people viewed this question
Top Bruder Toys Experts
MarK
Level 1 Expert
ptpumpman
Marc Taylor
Are you a Bruder Toy Expert? Answer questions, earn points and help others
