Question about Lacoste Clothing Accessories
Need pad replacements for lacoste reading glasses
Where can I buy a replacement watch strap for my Lacoste 2500g watch?
Any good watch shop should be able to fit a band to any watch
Jan 28, 2015 | Lacoste Watches
Need to replace mirror glass and base corsa c 2002 sxi driver side
when you buy a new glass look for one with the heater pad on it. you can buy the heater pads new but its cheaper to get them with the glass.
Dec 15, 2013 | 2002 Opel Corsa
I need to replace the seal AND the inner door glass on my Jenn-Air sve47600 range. Haven't found anything online that helps with the glass replacement. Another question: above the oven door (and...
Hello & Welcome to FixYa
The heating issue can be caused by the oven temp sensor that is bad and needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement. You can view this video for glass replacement:
Please get back to me if you have any other questions.
Kevin
May 28, 2011 | Kitchen Ranges
One of the legs of the sunglasses broke off. The hinge is still attached to the leg of the sunglasses.
You may need to replace or rescrew on the other leg, usually done using a small glasses repair kit.
Apr 19, 2011 | Lacoste Clothing Accessories
The print is so small I need a magnifing glass plus my glasses to read it. how do I enlargee the print
Change the Display screen resolution to a lower setting, I suggest 1024X768
Go to Control Panel - Display - Settings - move the slider in Screen resolution to a lower setting.
Feb 09, 2011 | HEWLETT-PACKARD 448618-001 - Pavilion...
I need a replacement band for my lacoste watch model 3530G
Contact Lacoste at: (309) 692-2837 use extension 508 for the parts department.
Jan 19, 2011 | Watches
MP830 Pixma
Do you mean that when you Send or Copy you get dark lines, but when you receive a fax or print from a PC it looks OK?
If so, this is usually caused by a dirty document feed glass. Get a rag and some alcohol. Open the upper lid so you can see the glass. On the left, you will see a strip of glass that goes from front to back. Put the alcohol on the rag and glean the glass. Usually there is white-out from faxing documents before they are dry (don't make so many mistakes). Let the white-out dry before faxing the document. More rarely, the culprit is the residue from stickers or tape. The latter can be hard to see, but cleaning the glass should fix the problem.
Clean the flatbed glass with Windex, look at the white pad under the flatbed cover (very large rectangular pad). You can use the alcohol to clean any pen marks off of this pad.
Nov 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Clothing Accessories Logo
Top Lacoste Clothing Accessories Experts
Da Doc
ray gallant
Are you a Lacoste Clothing Accessory Expert? Answer questions, earn points and help others
