Question about RCA 32V550T 32" TV
Tuning problems My set is ok as long as you do not change the channel. When you change the channel the sreens goes black with white lines. I then have to shutdown and unplug the tv. after about 5 minutes the picture comes back when you turn the tv on again. This tv is only about 2 & a half years old.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is due to loose contact near 1 anrena or cable socket. 2 cable wire loose. 3 loose contact near tuner. 4 tuner b+ line or agc line loose. 5 horihontal hold tunning is not proper.or control loose. hope this will help. good luck.
Posted on Sep 29, 2007
I am play vcr audio is ok but disply not in the screen vertical backgrond is black & full screen only two white line equali so main display problem so pls help this problem sir some body help me.
I think you are seeing the tuning screen for TV's to be tuned in. Look round the back of the VCR for a switch called TEST Signal. If it's ON set it to off.
May 11, 2011 | Televison & Video
Picture goes in and out
This will require you opening the back cover of the television to test some component with the use of an ohmmeter.
This may be a slight drift - like someone is messing with the fine tuning
or such a substantial change in tuning frequency that the channels go by
as though you are surfing.
Possible causes depend on tuner type:
1. Quartz tuner (10 button direct access digital synthesizer) - For a
slight drift, a component is probably changing value, possibly the
crystal in the reference oscillator. For gross changes - flipping
through channels - it is more likely to be a digital control problem -
the microcontroller is misdirecting the synthesizer to change frequency.
2. Varactor tuner (buttons but not direct channel access) - If only a
single pushbutton selection is the problem, the the varactor tuning diode
for that button is probably changing capacitance. If all channels in
a band (Vl, Vh, U) are having a problem, it is more likely to be a
drifting D/A or faulty AFT (Automatic Fine Tuning) circuit or power supply.
3. Turret or switch tuner (Knobs) - A component like a capacitor is changing
value.
You will have to get in there with a heat gun or cold spray and track it down
the old fashioned way. At least, the problem is almost certainly localized
to the tuner box (and possibly the controller if applicable).
As noted, gradual slight changes in tuning are likely due to frequency
determining components drifting.
Uncontrolled channel surfing is probably a logic problem. For the
quartz tuner, this could still be marginal connections causing the
microprocessor to misdirect the synthesizer to change channels.
For the latter case, particularly, the cause may still be bad connections
resulting in loss of channel memory and/or erratic behavior.
Take care...
May 21, 2010 | Mitsubishi WS-55859 55" Rear Projection...
White Screen Of Death
MY IPOD IS IS HAS A WHITE SCREEN
Feb 08, 2010 | Apple iPod nano
MY SREEN GOES BLANK(white) WHEN IM ON IT WINDOWS VISTA
my acer aspire 9300-5349 orbi cam show black screen, how can i fix it..
Nov 10, 2009 | Toshiba Satellite A135-S4527 Notebook
Black and White Channel
Check the fine tuning for that channel.Adjust + or - accordingly, see what happens?
Oct 02, 2009 | Apex Digital AT2708S 27" TV
Cable on TV suddenly went to black & white (and a bit fuzzy)(some channels show faint colour). Was fine, nothing was changed, one day was suddenly B&W. TV screen is not the problem, all other cable...
Was playing around with the TV's menu and changed the Tuning Band from "HRC cable" to "IRC cable". Suddenly I have colour again. No one had adjusted any of the controls, so still not sure why one day it was fine and the next day it had gone to black and white, but changing the Tuning Band fixed the colour problem for me.
Sep 13, 2009 | Televison & Video
Color problem
Please fine tune those B/W channels to obtain color picture. If TV is more then 4 - 5 years old, it needs resoldering in tuning area or might need replacement of IF block.
Aug 01, 2008 | JVC AV-21meu 21" TV
DVD player will only play in black and white
are you using a/v inputs or composite inputs .
Mar 27, 2008 | Disney Princess TV/DVD Combo
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Help
Not a home repair take it to a repair store.
May 24, 2007 | Apex Digital PF3230 32" TV
RCA 32V550T 32" TV Logo
52 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
