Question about Kenmore Elite 45986 Front Load Washer
Kenmore Front Load Elite Washing Machine
Front belose (seal) leaks. Have purchased new seal from Kenmore and installed twice. Both times screw clamp holding belose to drum fell off during wash cycle. What am I doing wrong? Could I be tightening clamp too much? If anyone can help me, it would be greatly appreciated.
  • Anonymous Dec 03, 2008
    the clamp seal fell while washing and i donot know where it came from so i donot know how to put it back
  • 447 Answers
You must ensure the boot is properly seated on the outer tub, There is a groove in the lip of the tub and the boot,make sure grooves are fully mated. Also try getting a new clamp; the screw can back out releasing the tension,also fold the excess clamp that passes through the screw over backwards preventing the clamp from loosening, a few dabs of good super glue helps too and can still be removed (dont use much a few drops in four places is sufficent).
Posted on Sep 27, 2007
We purchases a uses kenmore elite washing machine. When we hooked it up, and put the first load in and turned it on, water sprayed inside and leaked. We imediately unplugged the machine. Now we can
use a t-20 torx or a 7 mm socket to remove the toe kick under the door. then on the right side under the door, reach up inside the front panel find the door lock. at the bottom of the door lock you will feel a flat circular tab. pull the tab about a half inch and PULL ON THE DOOR AT THE SAME TIME.. then start washer and see if you can determine where water is leaking. if you can replace a simple part and repair it, use your model# and do a google search for parts.
May 13, 2012 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite front loader washing machine and the problem is that the rubber gasket ripped causing water leak
Nothing to do there but replace it. Call sears service with your model#, serial# and date of purchase to order one.
Nov 29, 2010 | Kenmore Elite 45986 Front Load Washer
The wash load dial is loose on the Kenmore Elite
Purchase a new one. It is slip/pressure fit. If it is loose - the hole is dogged out and it cannot be repaired.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite front loader leaks
well you can remove teh boootm acess panel by removingthe 3 screws that run along the bootm of the unit . afete rthat you can set a cycle to wash ans see where the leak is coming from
Jan 28, 2009 | Kenmore Elite 45986 Front Load Washer
Water on the floor
hi thanks for the question i would remove the front panel 2 screws on each side at bottom that's where the water pump is located you could have a pump problem thanks the appliance doc
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite Calypso won't drain
The most likely thing to cause the code and the leak is the water pump. If the shaft seal on the pump leaks, the water gets into the drain pump motor and shorts it out. The code is telling you there is a high current/amp draw at one of the motors.
You can see if the pump is leaking by tilting the machine back, removing the screws that hold the bottom to the front edge of the machine and looking at the pump. If the pump is leaking, you will need a new pump and possibly a new motor control board.
Post back if you need further instructions and we will walk through the repair.
Nov 09, 2007 | Washing Machines
Kenmore elite top load about 3 years old
Check the boot for tears, also remove the lower axcess panel (Three torx screws or 7mm) and see where the water is coming from.
Sep 24, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
75 people viewed this question
Sal De
 Brian Main
Brian Main
