Aoc monitor sound e2752v - Computers & Internet
Replaced ph monitor with aoc,no sound. do I need seperate speaker/s? my hp had port for sound cable from computer,aoc does not.?.
attach speaker on to the green port on the back of the cpu, then play sound, before this also check whether the sound driver is installed or not in device manager
Jul 29, 2011 | AOC Monitor
Screen+ application that came with my AOC monitor isnt working when I try to change the configuration to multiple on display 1 or display 2. What happens is "AOC grid screen executable file has...
This sounds like a computer problem and not really a television problem. Check your driver files.
Try removing your driver files. Then disconnect your AOC monitor. Reboot the computer and login. Shut down the computer and reconnect the AOC monitor. Start the computer. Now install the monitor drivers.
Jun 27, 2011 | AOC 23 E2343fk 23 LCD TV
New AOC monitor. No sound . when i insert dvd which was in the package it just promotes AOC products
Did you plug the sound sable into the audio out port on your computer?
The VGA and DVI monitor cable/plugs do not have sound capability so if there are speakers on your monitor they need to get the sound signal through a separate wire.
HDMI can send sound so if your monitor is hooked up via HDMI it should be able to pass sound as well (at least in most circumstances).
Mar 12, 2011 | AOC Monitor
My aoc monitor 2216sw shut down after three seconds on
It sounds defective. When the high voltage power units stop working; you will experience this type of problem. I would call AOC and see if the monitor is under warranty. Otherwise, seek an alternative monitor to use.
Jan 06, 2011 | AOC 2216SW Monitor
Aoc 2230fm monitor sound is not working
hi there
you have to check your aoc male to male audio cable for this
check out audio setting in aoc moniter menu
check out for user mannual
Jan 03, 2010 | AOC Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
