Question about JVC AV-32120 32" TV
JVC AV 32120
This is at a school, the sound plays fine, the picture (from a DVD player) sits in the background behind a black box that takes up about 2/3 of the screen centered. The menu comes up with the remote, but when I try to go into the V-chip or any other setup it is locked. I am wondering how to get the black box gone. I half suspect that a student passworded the screen and I don't know how that would be reset.
    Sniper:
  • 140 Answers
Sounds like your "CC" (closed captioning) is turned on and it is set to text mode.Go into the menu and turn the closed captioning "off". The default v-chip unlock code is "0000"
Posted on Sep 27, 2007
SOURCE:
I do not have a remote control with my dvd player. How do I tune in my dvd player to my jvc tv remote? I can play dvd's but I cannot use the arrows to select options. thank you
U can't not tune tv and DVD player together.Each have own signal frequencies.Try website like Remotes.com to buy an original or very close to the original remote.
Dec 17, 2010 | JVC AV-32120 32" TV
Picture on my JVC AV 32120 is a little jumpy and has fine horizonal black lines going thru the picture. This happens if I use the cable connection or the RCA plugs connection. If I pound on the top of the...
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical. Be sure to vote/rate me if this helped Thanks!
Oct 19, 2009 | JVC AV-32120 32" TV
Koss dvd player kd305a plays black and white.
Check the av channel on the tv,the av is normaly av2,if it say`s any different then press the av button on the tv r/c until it plays in colour
Oct 15, 2009 | Televison & Video
In running a dvd as soon as i hit play a large black box appears covering all but 2" of the picture on all sides of the screen...i think it must be a setting but havent been able to figure it out.
This sounds like the text mode of closed caption but don't know why it would only be when playing dvd . Go into the setup menu of your dvd player and see if it has closed casption and if so turn it off. Hope this helps
Oct 13, 2009 | JVC AV-27820 27" TV
Black Square area on Screen
If you press display on the remote, it will go away. It will come back, it's a common fault for this set and theres a mod to be done to the eeprom.
Apr 24, 2009 | JVC AV-32120 32" TV
Our 32'' JVC TV model # AV-32030 has an obscured picture.
With the remote go to the Closed Caption menu and make sure it is turned off.
Let me know if this helps
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Apr 03, 2009 | JVC AV-32020 32" TV
Only plays one track from from DVD sound
Plug in center speaker -- seems right and left speakers are secondary carrying only the background / sound affects.
Jan 10, 2009 | Televison & Video
Rainbow of color when viewing DVD
TRY TO MATCH THE SYSTEM OF THE TV AND DVD. IF ITS NTSC SET IT BOTH WAY OR IN OTHER SYSTEM
Jun 06, 2007 | JVC AV-32120 32" TV
JVC AV-32120 32" TV Logo
140 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
