Question about Samsung Televison & Video
I need to connect a new Samsung PN 51F5300AF Plasma TY to my old Yamaha RX-V440 AV receiver. Can I use the digital optical connections?
skotkolr
  • 558 Answers
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Posted on Apr 27, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: I have a Yamaha RX-V363
There is likely a static charge (voltage / difference of potential) between the the receiver and the TV.
They should have their grounds tied together. This should be covered in your owner's manuals.
In some cases, there may also be a stray voltage on the cable line's ground. If grounding the two together doesn't work, you may want to call the cable company (or you or a friend may be able) to check the cable line for a stray voltage or bad ground.
Posted on Nov 08, 2008
  • 4234 Answers
SOURCE: can't play audio CDs without having the TV on
Your description is not entirely clear, so I have to guess a little here, but I think what is happening is as follows:
1) You are using your DVD player as the source for the CD.
2) Your DVD is connected directly to the TV and the TV then connected to your receiver.
If the above are correct, then the problem is that the TV only has what is called an ACTIVE passthru for Audio signals. This means that the signal is process by the TV and tehn sent to the audio output jacks. With the TV off, the buffer ICs are not functioning, thus no output. Some older sets have what is called PASSIVE passthru.
I don't know your specific DVD model specs, so check to see if you have 2 audio outputs from the DVD (many do) and connect the other audio out directly to the receiver. That will resolve your problem.
Dan
Posted on Mar 20, 2009
ginko
  • 19396 Answers
SOURCE: When i connect my LG
Hi.
You need to select optical input function on the Home Theater. See page 22 in this manual.
If that is not enough you may also need to select the optical audio out enable function on the TV. That depends on the model of your Samsung TV. Please give us model number.
If all that is not enough try turning off TV and Disk Player. Disconnect power from both. Connect back and restart both devices starting from TV. Keep the optical cable connected while you perform the power reset.
If that still does not work the cable may have been damaged while connecting/disconnecting. Test using a different cable or test the cable using different devices.
Posted on Aug 30, 2011
I need to conenct yamaha rx v420 to Samsung tv
Unless your Samsung has optical digital entries, I'm afraid you can't use them together in high quality.
Today, everything is connected through HDMI. Your Yamaha receiver has only analog connections. As well in as out. Although on the left side, when you look from behind, there are some digital connections.
I found the manual still online, so if you don't have one, click the link below.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V420.pdf
Mar 31, 2014 | Samsung Security Cctv Sod-14c Soc-120...
How to set a RX-V440 in order to be able
Check the settings. refer to its user manual.
Jun 03, 2012 | Yamaha Audio Players & Recorders
I have an old Yamaha RX-V793. It works perfectly fine. Now I have a new LCD screen, a new DVD player and my new cable tv set top box. All 3 take and use HDMI. I'd like to be able to HEAR BOTH my DVD...
hi,
u can make connections only through digital inputs(optical and coaxial). u can connect the digital outputs of ur dvd and cable set top box to the receiver. no way to connect HDMI. HDMI is a high definition media interface. for using it u have to go for a av receiver that supports HDMI.
ok
Dec 23, 2010 | Yamaha RX-V793
Can I connect component av cables "in" to my Yamaha RX-V365 and connect "out" to my TV and get both audio and video?
Receiver does support 3x component inputs and one component output. Both these can carry only video signal, not audio. So you have to connect audio separately, either stereo via analog 2x RCA connectors and digital SPDIC via optical (2x) or coaxial (1x) cable.
Feb 23, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Jan 06, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
I'm trying to run the optical from my playsation to this reciever rx-v440 but i'm getting no sound whats gives??
Go to the Yamaha's main menu and check your "audio Input" setting. It should be on "Auto". If you need further help, post a comment and I can help you further.
Aug 09, 2009 | Yamaha RX-V440 Receiver
Problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Dec 01, 2008 | Yamaha RX-V461 AV Receiver
Televison & Video Logo
Henry  Thomas
Henry Thomas
