Question about Advantage Industries 5-Function Promotional Pedometer
AD-288 interior health 5-function pedometer - Advantage Industries 5-Function Promotional Pedometer
I am 77 years old, hard of hearing, but otherwise in reasonably good health. In setting my 4202 pedometer I was confused about setting a goal.
Hello
You can di it either way whichever is better for you. I would have thought a daily target would be better as you might get to day 6 and realise you are a bit behind :>)
Your manual for the 402 is here
USER GUIDE
pdfstream.manualsonline.com/.../ae0d0b2f-3e75-4028-a741-89a5d...
Translate this page
1- INTRODUCTION. Back cover. 4202 PEDOMETER. USER GUIDE. /INSTRUCTION MANUAL. Congratulations on your purchase of a Sportline 4202 Pedometer. The 4202. Pedometer features a highly advanced pedometer technology that accurately measures your body movements when worn from multiple locations on ...
Mar 21, 2018 | Sportline Exercise & Fitness
How do I change the time
Change the time on your pedometer this weekend ...
blog.walkingspree.com > Walkingspree
To change the time on your Omron USB Pedometer press SET and hold it ... AM and PM displayed on your pedometer or it will reset at noon instead of midnight.
[PDF]PEDOMETER - LuckyVitamin
www.luckyvitamin.com/.../Sportline%20Qlip%20Any-Wear%20Pedome...
8. SETTING THE PEDOMETER FUNCTIONS. SETTING TIME. 9. SETTING USER DATA. 10. OPERATING THE PEDOMETER. VIEWING PEDOMETER DATA. 11.
How to Set Up Your Pedometer - YouTube
? 1:51
https://www.youtube.com/watch?v=2Zgh9uDeA4w
Jan 31, 2016 | Exercise & Fitness
How do I reset the time?
How to Configure Your Omron HJ-303 Pedometer
www.walking4fun.com/.../pedometers/...pedometer/how-to-configure.ht...
When your pedometer first comes out of the box, you'll need to configure it. When youchange the battery, you'll have to reset the time on your pedometer, but the ...
[PDF]Getting Started: Setting Up Your Pedometer
www.whoi.edu/fileserver.do?...
Woods Hole Oceanographic Institutionyour pedometer and walk your way to better health. Pedometer Setup ... down theRESET button. Additional ... you'll track steps, time, and miles throughout your daily routine. And, in ... Do the math: 20 divided by the number of steps equals.
How to Reset an Omron Walking Style Pedometer ...
www.livestrong.com > Sports and Fitness
Oct 28, 2015 - Your Omron pedometer is a fitness accessory used to provide a great amount of ... session, including steps taken, time walked, distance traveled and calories burned. ... Do not use the end of a pencil to perform a system reset.
Dec 14, 2015 | Exercise & Fitness
How do I turn on the pedometer on my new samsung s5
The Pedometer is found under the S Health App. If the Pedometer has been turned off, there is an option to Start at the base, if it's active it will have a Pause option. I'm presuming your just need to hit Start to get it working again.
May 08, 2014 | Samsung Star GT-S5233 Cell Phone
How do you turn it off? Why is cario function shown unpredictably?
It´s hard to believe, but there is a pedometer manual search engine, they may get it within hours. Just send them a request!
Aug 25, 2011 | Brunton New PedCardio Pedometer with...
How do you change the battery on the Sportline, fitness pedometer 360?
The battery hatch is at the bottom of the pedometer. Just slide the hatch open with your fingers and then pry battery out. Put in the new battery in the same orientation (positive up on most). I find shaking the pedometer works to get the battery to fall out. If my fingers don't move the hatch, I use a small flat blade screwdrivers.
I hope this helps.
(on my pedometer (a similar model) the hatch is on the back with a slot to slide in a finger nail and wraps partway around the hinge)
Aug 08, 2010 | Sportline 15 Function Total Fitness...
Reebok B 2 pedometer
1. Reset pedometer by pressing the reset button.
2. Find a long open place and take 20 steps with the pedometer
closed.
3. Check the number of steps the pedometer counted. It should be
between 19 and 21 steps.
4. If the count was not right, try to move the pedometer forward
(toward your belly button) or back (toward your hip) on your
waist.
5. Repeat this until you get the best count of your steps.
6. Once found, place your pedometer in this spot each day.
Apr 24, 2009 | RTO Reebok CS-1 Pedometer
Advantage Industries 5-Function Promotional Pedometer Logo
81 people viewed this question
Top Advantage Industries Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Advantage Industries Exercise and Fitnes Expert? Answer questions, earn points and help others
