Question about Crafts & Hobbies
Bought a 352 ice station no instruction on how to hook to wire it? help ?
How to hook up all the wires back onto the battery since I'd just bought a new battery and I'm trying to hook the battery back together
Keith, If you have the correct battery( size and correct cable terminals) you may have to give the wires a little tug to give a little more length, stretch so the wires are easier to put on. The wire with the red end goes to positive on battery. If battery in trunk the battery connections face out. I will put links below, hope they help.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Maserati Tutorial Accessing the Battery Quattroporte
Mar 02, 2016 | 2008 Maserati Quattroporte
I bought a Logik car radio but every time I switch my car on I have to set the station and the time all over gain.. I dont even bother to set the time because it changes back to Midnight every time I
you forgot to hook up wire to fuse box with all time connection to power even when car is off.if u connected thw stereo red wire positive black ground theres always another wire yellow/blue/orange that needs to be connected to constant power that wire once connected will have all ur memories stations set and clock.ned to check wiring
Mar 03, 2014 | Car Audio & Video
Radio diagraham
get a wire tester. One end has an alligator clip the other looks like an ice pick with a light in it. put the alligator clip piece on a grounded object. Turn the key on. Poke the ice pick end onto each wire. the wires that cause it to light up are the hot wires (power going to them) sort them out separate. now turn the key off. Which ever of the power wires doesn't light up with the key off is the wire that turns the radio off with the key. However the main (usually yellow wire) on the radio need to be hooked to a wire that has constant power as thats what stores all of your stations and keeps the time on the clock.
Jul 11, 2012 | 2008 Dodge Avenger
I have just purchased a Logicom OLEA 350/352/353 Cordless telephone and need a user manual in English
dear All please help me I purchase a phone logicom Olea pop 350
And Olea Classic 352
could you send me the instructions guide in English
Here is my email
rania.sayed@charmaine.com.eg
Nov 01, 2010 | Lands Phones
Hooking up water to ice cube maker
On page 4 step 3 of the manual on link below tells you how to hook up the water supply for your fridge.
http://shop.amana.com/assets/pdfs/literature/004251.pdf
Mar 13, 2010 | Amana 22.6 cu. ft. Side-By-Side...
I need the instructions for the slushie maker.
Check out your manual. Usually, a manual will have recipes for you to use. If you don't have the manual, you might want to look into contacting Bunn to get one (usually they can send them out for free!). Their phone number (according to their website, www.bunnomatic.com ) is 800-352-2866
Good luck! :)
Aug 26, 2009 | Bunn Margarita Machine Ultra 2 Slush...
I bought a car stereo but it wont save presets.
make sure you have the yellow fuse wire hooked up to bat. power (always hot) red wire is your ignition power
Nov 12, 2008 | Pioneer DEH-1600 CD Player
Ice maker not getting water in the line
The only other component stopping the valve from putting water into your icemaker is the icemaker itself. Replace your icemaker and you should solve your problem.
Nov 14, 2007 | Amana ARS2464B Side by Side Refrigerator
Cdx m 630
Do you lose them only after the car is turned off? if so, your 12 volt Costant wire (yellow) is hooked to a switched 12 volt source.
Nov 08, 2007 | Sony CDX-M630 CD Player
Open Questions:
Crafts & Hobbies Logo
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
