Maytag 745g after agitating the water don't drain.
IFIXALL
  • 868 Answers
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
  • 217 Answers
SOURCE: agitator wont spin
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
Maytag Dependable care washer.....Locate a 1/4 inch screw on the side of the agitator, ( about 3/4 of the way down) remove this screw and lift up on the agitator...picture.
Maytag Atlantis, Norge, Performa by Maytag.....Remove the cap and softener dispenser by pulling it off and locate the agitator bolt, remove bolt and lift up on the agitator...picture.
Posted on Nov 29, 2008
honeymokey
  • 3113 Answers
SOURCE: Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Posted on May 17, 2009
  • 219 Answers
SOURCE: LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
Posted on May 21, 2009
praky16
  • 744 Answers
SOURCE: my maytag washer model pav3360 will not agitate
hi..
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=3048&modelDesc=WASHER&modelNumber=SAV365AAWW&documentID=M0512408&documentTypeID=PLDM&documentClassCode=PV&titleType=TUBS&titleID=00007&
I sent this diagram to see if maybe you were looking in the wrong areafor the hold down bolt. It should sit down inside the auger tower afteryou remove the fabric softener cup (be sure you remove all the cupassembly on some models, they can separate). I havent seen a Maytag (orMaytag hybrid (i.e Amama) or others) not have a hold down bolt, but Icould imagine there might be.
thank u
rate me
Posted on Jul 20, 2009
Maytag Centennial Top Load Washer drains as it fills.
The water is probably siphoning out of the tub. Your drain pipe is either too low or the drain hose is down too far into the pipe. Take the drain hose out of the pipe and lift it high. I'll bet your problem goes away
Feb 06, 2014 | Maytag Centennial Top Load Washer
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
May 20, 2009 | Maytag PAV2300 Top Load Washer
May 17, 2009 | Washing Machines
Wont drain,spin,or agitate
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Dec 27, 2008 | Maytag PAV2300 Top Load Washer
When washer finishes there is a dripping of water inside unit
What has happened is you have sand in your water valve from your water. This pluggs the water valve and also sticks it open so when the water valve shuts of there is still a small trickle of water coming through the washer. Replace the water and it will fix the problem (no way of cleaning the inside of the valve.) Replace water valve.
Nov 24, 2008 | Maytag Washing Machines
Maytag mav6000awq repair manual
No I don't. Also I couldn't find the model on the pull down but the Maytag is 745G model LAT8650AAL
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
