No Camshaft Position Sensor Circuit Failure
Possible Causes:
CMP Sensor connector is damaged, open or it is shorted.CMP Sensor signal circuit is open or shorted to ground or to battery voltage or 5v supply circuit.CMP Sensor 5v supply circuit is open or shorted to ground or to battery voltage.CMP Sensor ground circuit is open.CMP Sensor is damaged or has failed.CKP Sensor is damaged or has failed.PCM has failed.Trouble Code: P0700
Automatic Transmission Control System Malfunction
Possible Causes:
.The presence of this code means the TCM detected a problem.TCM related Sensor has solenoid is damaged or has failed.This code is for information only - check for other TCM codes.TCM or PCM has failed.Sorry but the PO620 is not listed.
Camshaft Position Sensor Circuit Intermittent
Possible Causes:
.Wiring harness fault.5v supply circuit open or shorted to ground.Tone wheel/pulse ring is damaged or corroded.CMP Sensor has failed.CMP Sensor signal circuit is open, shorted to ground or battery. voltage or 5v supply.CMP Sensor ground circuit is open.PCM has failed.Trouble Code: P0016
Crankshaft/Camshaft Timing Misalignment
Possible Causes:
.Base engine problem (i.e., the camshaft timing is not correct).Intermittent condition.CKP or CMP Sensor signal is erratic (check with lab scope).Tone wheel or pulse wheel is damaged or contains debris.CKP or CMP Sensor, harness or connector has failed.PCM has failed.Trouble Code: P0061
Engine Temperature Control Level 2 RPM Performance
Possible Causes:
PCM need to be reprogrammed.PCM has failed.
Trouble Code: P0340
Possible Causes:
PCM has failed
Trouble Code: P0113
IAT Sensor Circuit High Input
Possible Causes:
IAT Sensor signal circuit shorted to VREF (5v)
IAT Sensor signal circuit is open, or the ground circuit is open
Trouble Code: P0123
TP Sensor/APPS Circuit High Input
Possible Causes:
Related TP Sensor engine DTCs present
Intermittent wiring or connector problem
TP signal circuit is open or is shorted to battery voltage or to 5v supply circuit
TP sensor has failed
TP sensor ground circuit is open
PCM has failed IAT Sensor is damaged or it has failed (an internal open circuit)
PCM has failed
