Question about Zenith SY2551S TV
No picture Having a video problem building up for several years. Every once in a while the picture color goes reddish, like everyone on the tube looks like they've spent waaayy too much time in the sun and any landscapes look like photos from Mars. I twist the video plug and/or spray contact cleaner on the video RCA jack and everything's fine. However, for the last month it happened several times per night, then all picture disappeared. When I pull and insert the video cable again, the screen gets white horizontal streaks for a split second, then back to no picture. Not sure if replacing the little sandwich board that holds the RCA connectors will do the trick, or if the tube is toast. Speaking of toast, I never smelled any smoke! :-) Thank you!
    An expert who has answered 500 questions.
  • 556 Answers
Gets white horizontal streaks for a split second, then back to no picture. i think sound will be alright. while horizontal streaks are called retace lines & is due to video section failure. please call skilled tech to fix it it is not a major problem & can be rectified. at your place without replacing much parts. your tube is ok. good luck
Posted on Sep 27, 2007
Model ds31590 screen has a reddish purple tint whether it s on tv or video i have already tried to change all picture settings and set back to factory settings still has same problem,here is an example...
Chances are real good that your picture is showing its age. There are three color beams in the neck of the picture tube. When these electrodes are operating correctly the will produce an arc, that will produce the proper voltage for color correction. Much like the spark plugs in your car. When you have a fouled spark plug, you replace it. In the case of a TV, replacing the tube is the best way to correct the picture you are looking for. It would be to costly to do this of course. Another option is to rejuvenate the picture tube. Once again, rejuvenating the picture is last resort. Customers must be warned that rejuvenating may work or even in some cases destroy the picture tube. I want to remind you as well, the symptoms you describe will over work the main board as well. This TV is not feasible for repair. Thanks for asking and show a few hands of support!
Mar 26, 2011 | Sanyo DS31590 31" TV
I have a sony wega and the picyure is clear but has a green tint what could that be
There are several possibilities in that area. The Picture Tube (CRT) is driven by three different video signals. One presents the Red, one the Blue and one Green. All other colors are derived from a mixture of those three colors. The greenish tint could be a sign that the green gun is being over driven or the Red and the Blue are less than adequate to create a normal picture. Sorry to say this but the most common problem that causes that symptom is the emission in the "gun" assembly inside the picture tube is declining with age and hours of operation. Sony Picture tubes are typically good for around 40,000 hours of use. I don't recommend replacing the picture tube. If the set is more than 5 years old I would suggest that you start looking for a new set.
I know this is bad news but I am just telling what I know the most likely scenario that I have seen in 35 years of TV service.
May 29, 2010 | Sony Televison & Video
I have a Phillips Magnavox HD Tv Rear Projection Television and the picture looks greenish and reddish and is blurry on the text of the screen? please help.
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
Dec 23, 2009 | Hitachi 57F710 TV
We have a 32" standard sharp tv about 10 years old and we are having trouble with the picture. There are colored dots all over the screen.
Dear sir,your television is very old ,so picture tube is weak for this reson color dot all over the screen, replace the tube then is ok.
Nov 23, 2009 | Sharp 32C-240 32" TV
Video color
Hard to tell, but my first guess is that the green or blue video amp, or guns on the picture tube have failed.
Jan 10, 2009 | Samsung HCM553W 55" Rear Projection...
Screen colors not constant
You probablly have bad solder joints on your Video driver transistors, which arre located on each Picture Tube. You can only get to those by going through the front, grille cover
Apr 10, 2008 | Pioneer SD-P62A5-K TV
25 inch sanyo tv
If the horizontal lines going through the picture are fine white lines, then I would suspect the picture tube as having a heater to cathode short or some other problem. Since some sets have had a 3 year warranty on the picture tube, you may be lucky unless the labor to replace the tube is more than the set is worth. Sanyo is usually not a good name in consumer electronics anymore, so if you're looking for a replacement I would look elsewhere.
Mar 31, 2008 | JVC AV-32F704 32" TV
Color out of wack
There are only two things can cause that problem out of value resistors on video stage. or weak picture tube . the first one 60 to 80 dls dependig on the tech ,at shop service 125.00 if is the picture tube more than 450.00 good luck and let me know thanks
Jun 12, 2007 | RCA F32649 32" TV
Poor color issues.
try adjusting the convergence. good luck and happy valentine!
Feb 14, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
