Question about Humminbird 386ci Combo Fishfinder and GPS
Hummingbird 386ci: it worked a couple days ago when I was fishing and today it did not even turn on. I have good power to it. I bought it around last may 2013
5 Suggested Answers
Editor925
  • 285 Answers
SOURCE: CAN I POWER MY FISH FINDER GOING DIRECTLY TO THE
Yes you can. Basically the red wire goes to the fuse box connection. The fuse box should then be wired into the positive battery terminal. The black wire is the negative ground wire and needs to go directly back to your negative battery terminal or to a common negative buss bar.
Posted on Jun 15, 2009
  • 3 Answers
SOURCE: hummingbird 570.....after about 10 minutes
I had the same problem.A new transducer got it working.
Posted on Aug 30, 2010
  • 3 Answers
SOURCE: hummingbird 570.....after about 10 minutes of unit
Install a new transducer
Hobbit_who
  • 2044 Answers
SOURCE: hummingbird matrix 12 not powering on
The Power Supply just crapped out, Sorry.....
Posted on Apr 12, 2013
Is the transducer for a hummingbird 386ci the same as for the 688 ci?
Hi Cliff
I believe your best bet here would be to contact Hummingbird directly. There's the contact page. Hope this helps you out.
-Steve
Contact Us
Nov 10, 2014 | Hummingbird GPS
Hummingbird manuals
Hummingbirds web site offer downloads for their manuals.
Aug 26, 2014 | Boating
My hummingbird 175 does not show fish contacts
Obviously your hummingbird has stopped humming.
Check the most obvious things first. Power to the unit. Correct voltage at unit (no volt drop). Does the main box power up and appear to function OK. Then Check the Transponder connections. Clean with contact cleaner or methylated spirits & dry. Check for transponder cable damage. Try connecting a replacement transponder. Swapping parts to a certain what is working and what isn't. If you don't have parts then it will have to go to a dealer that does.
Good Luck
Jul 22, 2014 | Boating
Hummingbird matrix 12 not powering on
Apr 12, 2013 | Humminbird Matrix 12 Fishing System
2003 GMC 2500HD Duramax, truck will not start, bought a new battery, truck will not even click over. Listen for fuel pump and it's working. What else is wrong?
The only thing I can think that it would probably be is the ignition. Not where you put your key but the box with all the wires going to it under your steering column. Hope this helps. good luck
Jun 28, 2012 | GMC Cars & Trucks
New notebook w/new battery. Battery doesn't seem to charge even after machine is on for many hours.
Most laptops need 24 hours when their battery is first charged - but this is not normal it should last longer than that on batteries- i reccomend charging it for 24hrs minimum with it off then get back to me if that didnt fix the problem
Hope i could help
CBZ
Comment if you need more assistance
Apr 27, 2009 | Acer Aspire One PC Notebook
Hummingbird GPS Matrix 12
evidently the installer put 2 inline fuses to the power line. After more investigating I located the second fuse which was blown.
Jun 22, 2008 | Audio Players & Recorders
No power to my Hitachi 42hdm12
Hi, If even trying the TV in another known good outlet, it still doesn't work, do a hard/full reset - turned off via master power or unplug for a couple of hours. If all else fails, maybe you should seek the services of a qualified professional since this involves opening the unit, circuitry diagnosing and board/component repair/replacement. Hope this be of some help/idea.Post back how things are or should you need further information. Good luck and kind regards.
Aug 26, 2007 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Humminbird 386ci Combo Fishfinder and GPS Logo
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
