How to find the grub rescue mode in windows 7 laptop
3 Suggested Answers
krava
  • 64 Answers
SOURCE: I installed linux ubuntu remix
What you need is SATA controller drivers to be downloaded while starting windows xp disk or ERD Commander.
Since Asus Eee does not have an internal Floppy Disk Drive (FDD), you need to use an external USB FDD.:
Step one: You would like to connect an external USB FDD.
Step two: copy scsi/sata Hardware Access Layer (HAL) Drivers for you laptop to a floppy disk
Step three: during the XP boot process press F6 and follow the prompts to insert a floppy disk with HAL scsi/sata drivers.
Step four: Finish the boot process and run fix MBR.
There is another easy way:
If you can get a Knoppix USB flash drive, you can boot it up from Knoppix and run the following command in the terminal window: sudo ms-sys -m /dev/sda.
Hope This Helps
Posted on Mar 02, 2011
  • 60 Answers
SOURCE: please help!! i can't open my notebook!!! when i
if you need a quick solution see this ubantu forum discussion
http://ubuntuforums.org/showthread.php?t=1357690
or else do a bit of research https://help.ubuntu.com/community/Grub2
Posted on Aug 05, 2011
PC Boot problem
Try to call experts for good result
Aug 17, 2016 | Computers & Internet
Have a dual boot system, windows7 & linux. tried to update to windows 10. stuck at grub rescue.
It sounds like grub can't find the correct partition to boot Windows 10. This should get you through it: http://askubuntu.com/questions/654386/windows-10-upgrade-lead-into-grub-rescue
Keep in mind that Microsoft never tested the upgrade on a system that dual boots with Linux and uses the Grub loader. You are in uncharted waters.
Dec 24, 2015 | Computers & Internet
I deleted the allocated part of my hd on my hyundai laptop and now straight to grub rescue
You have lost all the data and windows that was on your HDD. You have to get the HDD working again and re-installl all your software.
Dec 20, 2013 | Computers & Internet
Corrupted os
Have you tried a System Restore/Recovery? Do you have a Recovery Partition? Take a look here: http://www.unixmen.com/fixing-a-few-common-grub-errors-broken-bootloader-and-error-1715/
Apr 29, 2013 | Intel Hasee Nb Q540x-n 13.3" Laptop...
Namco Hello Kitty: Roller Rescue for Windows wont run on windows 7
What version of windows 7 do you have? Unless you have windows 7 ultimate which has windows xp mode. it won't work.
Mar 05, 2011 | Namco Hello Kitty: Roller Rescue for...
I installed Ubunto 9.0 AND when it came up it said, GRUB LOAD,no such partition, then at a prompt it says,grub rescue.
If you run a dual-boot system with Linux and Windows, this has happened to you. You had to do your monthly reinstall of Windows, and now you don’t see the linux bootloader anymore, so you can’t boot into Ubuntu or whatever flavor of linux you prefer.
Here’s the quick and easy way to re-enable Grub.
1) Boot off the LiveCD
2) Open a Terminal and type in the following commands, noting that the first command will put you into the grub “prompt”, and the next 3 commands will be executed there. Also note that hd0,0 implies the first hard drive and the first partition on that drive, which is where you probably installed grub to during installation. If not, then adjust accordingly.
sudo grub
> root (hd0,0)
> setup (hd0)
> exit
Reboot (removing the livecd), and your boot menu should be back.
Only read below if Windows is now missing from the boot menu
If you installed Ubuntu before you installed Windows, then Ubuntu will not have anything in the grub configuration for Windows. This is where you’ll have to do a bit of manual editing to the grub boot menu file.
If you open the file /boot/grub/menu.lst with the following command:
sudo gedit /boot/grub/menu.lst
You’ll see a sample section for Windows, which you’ll want to uncomment and add to the boot menu list in whatever position you want it in. (uncomment by removing the #’s)
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
Note that you should also verify that hd0,0 is the correct location for Windows. If you had installed Windows on the 4th partition on the drive, then you should change it to (hd0,3)
Nov 20, 2009 | Canonical Ltd. Ubuntu
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
