Question about Onkyo New Original HTR990 Remote Control
Need HDMI board for htr990 - Onkyo New Original HTR990 Remote Control
Sony kdl-46z5100, good sound , no picture via hdmi ports. do get video using home function viewing internet choices and tools. Which board controls hdmi inputs ?
Whatever board is connected to the HDMI ports is the decoder board, this can be the main board or a separate board.
Feb 09, 2017 | Sony Televison & Video
Pioneer pdp-5070pu HDMI port 5 has a megenta hue to it. All other HDMI ports and component ports are fine. What board might need to be replaced?
The main board that has the HDMI ports on it. The numbers can be taken from the board itself. Once the board is replaced, you'll have to go thru all the setup menu's because the memory is on that board too.
Dec 27, 2013 | Televison & Video
My HDMI inputs dont work on my VIZIO gv47L FHDTV10A what board do i need to replace
Most likely you will need to replace the main board. That model # uses several different main boards. The part # will be listed on the board. Make sure you order the exact part # of your old board.
http://www.shopjimmy.com/vizio-3647-0012-0150-main-board-for-gv47lfhdtv10a.htm
Jan 05, 2013 | Televison & Video
HDMI cutting in and out.
some brands are known to have it be the HDMI port itself failing unbfortunately replaceing the main board is easier than repaceing the HDMI input on the board unless you have excellent soldering skills.
Dec 09, 2012 | Televison & Video
I have a kde-50xs955 sony plasma tv and now hdmi port stopped working. tried with new hdmi cables but no luck. cut power to reboot still not working. tried different devices and wont show it is even...
HI:
You need to replace the analog board assembly, this is the board that you plug connections into, seems the HDMI port has malfunctioned, there may also be a problem with the main board assembly that the analog board connects to.
Jan 24, 2011 | Televison & Video
I have an acoustic solutions tv, i use a hdmi lead to play the ps3 on it. The volume is not working tho, the hdmi lead works on other tv's and the ps3 volume is turned on, but i cant get the volume to work...
check the hdmi out with another device that takes hdmi, the hdmi system works on its own from the av board side of the av board. has its own settings. then main board will have a large chip on the board and this is the hdmi control chip. these can go on there own and not afect any other part of the tv
Jul 21, 2017 | iLO LCT32HA36 Television
Hdmi out [of amp damaged needs replacing onkyo tx sr605
You will need to contact Onkyo directly and request the board from the parts department. I was not able to locate a part number for this as we are usually requested to perform component level repairs for these units.
Dan
Nov 04, 2009 | Onkyo TX-SR605 Receiver
My hdmi port is not working
I have Verizon Fios and there's a known issue with the motorola HD boxes that they have bad hdmi ports, the screen goes green and that's it, nothing I can do about it I just use component cables. You need to be sure it's your tv not the cable box. Try the hdmi on a dvd player or ps3 or whatever else you have first just to be sure it's the tv at fault not the cable box. If you determine it is the tv you need to replace either the main board or the video board depending on your specific tv model. Some have the video inputs on the main boards some have video boards.
Aug 22, 2009 | Televison & Video
Toshiba 46H84 HDMI Card Replacement
The only thing I could recommend is to return the board and get the right board. open the set and get the part number on the board itself. You cannot modify a set to work things it was not designed for without reprogramming the microprocessor. Good Luck
Jun 26, 2007 | Toshiba 46H84 46" Rear Projection...
Onkyo New Original HTR990 Remote Control Logo
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
