Question about Goodman CKL60AR60 Air Conditioner
Outdoor unit compressor is not working model # AR60-1 Serial # 0106462633 MEA # 348-96-e Part # T14932017
    Genius:
  • Goodman Master
  • 1,363 Answers
Bad contactor or compressor
Posted on Aug 11, 2015
2 Suggested Answers
SOURCE: Trying to figure out how many tons our outdoor unit has
If you see any of these numbers that is your tonnage:
018= 1.5 tons
024= 2 tons
030= 2.5 tons
036= 3tons
042= 3.5 tons
048= 4tons
060= 5tons
Posted on Jul 15, 2010
Is there a reset button on a rheem outside unit?
Depending on what you are trying to reset. Most Rheem outdoor condenser units have a red reset button located near the copper refrigerant lines. This button is used to reset the high pressure switch. This switch is a safety for the compressor which protects it from running high head pressure, in case of a condenser fan failure, restriction is the discharge refrigerant line / condenser coil, etc. More information like a model number, serial number, is the unit not coming on, etc.
Dec 13, 2017 | Heating & Cooling
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
Fujitsu a/c outdoor model number AOTG12LVC indoor unit economy light flashing continuously, operation light single flash, timer light single flash this sequence repeats
Serial communication error. This means that the indoor unit is not communicating with the outdoor unit usually because the outdoor unit is faulty. You can check the indoor unit by switching it to 'fan' mode and seeing if all functions work normally (fan speed, louvers move as directed). If it responds normally, then it's probably ok so you can turn your attention to the outdoor unit. A common problem with the outdoor controllers is that they are susceptible to bugs, geckos, etc. shorting them out which will mean replacement of the board.
Mar 05, 2017 | Fujitsu Heating & Cooling
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
Error code timer light blinks twice
Depending on the model, this usually means "Serial signal (reverse) error at start up" which means that the indoor unit is not receiving a response from the outdoor unit when it tries to "talk" to it. It can be several causes but In my experience, it is usually the outdoor controller board. Again, depending on the model, there can be several boards in the outdoor unit any or all of which could be causing the fault as well as a faulty fan motor or compressor. The bottom line is that you are going to need a tech to take a look at it to diagnose properly.
Apr 07, 2014 | Fujitsu Heating & Cooling
My Carrier Tech 2000ss.The fan on the unit outside runs continuosly.The heat and cold work just fine,but the out side fan never stops.I was told ,that it is probably a relay switch.Tell me what you think.
Sounds like the fan relay is stuck and staying on so that the fan continually spins. Pretty common issue and shouldnt be to much for a tech to replace. If you do the job, just make sure that you get the right part. Parts house will need serial and model number for the unit
May 24, 2011 | Carrier Heating & Cooling
Indoor unit freezing up
THE OUTDOOR UNIT HAS A CONTACTOR WITH THE CONTACTS WELDED TOGETHER THE CONTACTOR CONNECTS TO THE COMPRESSOR AS IT TYPICALLY PULLS A SURGE OF 20 -30 AMPS OR MORE..WITH THE INDOOR UNIT IN FAN ONLY THE COMPRESSOR SHOULD NOT BE RUNNING. THE CONTROL WIRES GOING TO THE UNIT HAVE 24 VOLTS TO THE CONTACTOR TO PULL IN THE CONTACTS TO SUPPLY 220 TO COMPRESSOR.
Mar 09, 2010 | Heating & Cooling
My ge ac model APE07AHM1 is not blowing cold air. What could be the problem?
This is an old question, but I am having the same problem with APE07AHM1 that I bought second hand. I'd like to recharge it.
The answer by binev_78 seems to be for outdoor AC compressor units but this is a portable stand alone unit, no outdoor unit.
Aug 30, 2009 | GE APH10AA Air Conditioner
Air conditioning problem. unit, compressor
Look inside your outdoor unit and find the compressor tag. It should have a model and serial # on it and a manufacturer. Then do a basic search on the net for the distributor of your compressor. However, most distributors will not sell direct to the public. You will most likely need to purchase one through a contractor. If you email me your compressor information I can help you locate and price one out.
Jun 01, 2009 | Goodman CKL36AR36 Air Conditioner
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
May 16, 2009 | Fujitsu 24R1 Air Conditioner
Goodman CKL60AR60 Air Conditioner Logo
71 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
