Question about Homedics Digital Scale
My homedics scale displays inconsistent weight from the same surface weighing at the same time up to 6 lbs
3 Suggested Answers
  • 40 Answers
SOURCE: Have a Homedics scale SC430 - it consistently
look under the edge there should be a dial to turn
Posted on Aug 04, 2009
  • 16 Answers
SOURCE: My scale adds anywhere from
there should be a dial on the sides to zero it out. if it doesnt, then it has something to do on the actual scale. does it have a menu or settings option? you should be able to zero it out.
Posted on Dec 10, 2010
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
warranty@digitzscales.com
Aug 20, 2014 | Office Equipment & Supplies
I have two Weight Watcher scales, model WW11D. They weigh 4 lbs differently. One is 2 lbs heavy and the other is 2 lbs light relative to the weight registered at a Weight Watchers meeting. Is there a...
You say, that: "I have two Weight Watcher scales, model WW11D."
Can I have three guesses where you purchased them???
Do they come with any sort of warranty?
Their weight is inaccurate as compared to the official scales when you weigh yourself at the Weight Watchers meeting.
Are the people running the Weight Watchers meetings absolutely and totally unable to provide an answer regarding these scales?
Jul 04, 2011 | Vacuums
My scale adds anywhere from 5 lbs to 35 lbs to my family's weight. I just had my daughter weighed yesterday and this scale added 5 lbs and when my husband or I get on it, it adds anywhere from 30 to 35 lbs...
Dec 10, 2010 | Homedics Glass Digital Scale - Advanced...
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
Need to reset scale weight
You have probably set your scale to kilogram and not pounds. There should be a button to set this underneath the scale or even a reset button to reset the scale to its original settings.
Jul 08, 2009 | Homedics Glass Top LCD Digital Lithium...
Mini digital scale displays out2
I just had this problem on set Salter scales (says 3309 on label on back so assume that's model no) which came up OUT2 solidly after hadn't been used for a while.
Looking on WWW this means on other scales they need to be recalibrated. There are only 2 buttons on ths model ON/Zero and 2nd is mode for grams, oz etc. Discovered by trial and error have to hold down the on button and repeatedly click the measure button as it powers up, screen says err2 press on button again and says 5000g, put 5000g weight on scales, press on button again display says CAL press on button and it at first came up with EEEE and failed but next attempt it said PASS and it all worked again. I used 2 x 1.5kg bags flour and 2 x 1Kg bags sugar to make 5kg with bit tipped out of one to make exact and checked on another set scales. So trick appears to be finding how to get your scales in to calibrate mode and what the weight it expects is.
Jun 15, 2009 | Balance Health & Beauty
Can't find instructions for Homedics digital scales SC-390
EACH BUTTON IS FOR FOUR INDIVIDUAL USER. BUTTON ALLOWS YOU TO INPUT IDEAL WEIGHT (FOUR GOAL WEIGHTS FOR FOUR INDIVIDUAL USERS). AND CALCULATE AGAINST ONE OF THE FOUR INDIVIDUAL ACTUAL WEGHTS. i AM USER 1 IN MY FAMILY. I HIT THE 1 BUTTON, WEIGHT AND MY GOAL WEIGHT COMES UP BEFORE MY ACTUAL.
Feb 01, 2009 | Health & Beauty
Different Weights
201.4 bcs 205.4 not correct weight its depend on u r standing position and when give weigt on u r legs then weight change and u r 201.4 bcs is correct bcs weight depend on u r happness or tension and blood speed and plz reply
Oct 23, 2008 | Homedics Sc 535 Trifitness Healthstation...
Homedics Digital Scale Logo
74 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
