Question about Bosch Dishwashers
We have a Bosch sgs 4332 au unit. Went away for 3 months, returned and it would not work. Took it apart and reseated parts, now works fine, EXCEPT that when it fills with water, it overflows through hole in side mechanism, where inlet and outlet water pipes are connected. I can catch the water and dishes still come out clean, but would like to fix this as it is unusable effectively in this state.
catriver
  • 878 Answers
SOURCE: Water not getting to the upper level, dishes not cleaned.
Penrod, sounds like a circulation problem. Two things to check first. make sure the upper spray arm is not clogged with debris or split. Second is to twist and remove the filter and clear out any debris where the water enters the circulation pump impeller. If something has jammed the impeller, you would have to remove the dishwasher, remove the tank, remove the circulation motor and clean out the impeller...Catriver...post back.
Posted on Sep 03, 2006
gwshaw71
  • 83 Answers
SOURCE: Inlet/Outlet light flashing
check your overflow level switch wich is located behind front kickplate on right hand side
Posted on Feb 24, 2008
skrbin
  • 121 Answers
SOURCE: Bosch S9GT1B not taking water
check electro valve,water-level switch.
Posted on Feb 15, 2009
  • 234 Answers
SOURCE: Dishwasher does not fill with water when started. Problem began slowly with dishes not rinsing completely. Overfill float appears to work properly. Water fills pipe leading to fill solenoid but does n
I am almost certain that your problem is the fill solenoid.
If it does not work, there will be no water entering your machine.
I would either remove it and test it or just replace it at this point.
Tim
Posted on Apr 16, 2009
SOURCE: BOSCH SMS4472GB/20 DISHWASHER water leaking
Remove the side and top panels of the machine.
On the left hand side you will see a clear plastic panel full of tubes and small tanks. This is the metering tank. At the bottom left of this unit, is a black pipe held on with a clip. There will almost definately be a blockage between this point and the sump. You can either buy and fit a new pipe or do what I did with mine, which was to remove it and clean it with hot water and a bottle brush. Seems to work like new again now.
You'll have to get the machine onto it's right side to remove the lower end of the black pipe from the sump. I drained as much excess water as possible out of the machine by sitting it on bricks, tilting it to the left and catching the water in a dish as it came out of the float hole. Some will also come out of the funny plastic tube which runs across the top of the machine - I carefully removed this first and caught this water in a pan.
Drain the waste pipe and disconnect the water supply.
Replace the right side casing on to protect the feed to the upper spray unit and put the machine on it's right hand side. Once the machine is on its right hand side, fin the water inlet valve and carefully remove its bracket from the chasis of the machine. You will need cross head and a torx screwdrivers - one for each screw. Once this is loosened, push some of the water supply pipe into the machine so you can move the bracket to the right a little to gaine access to the waste pipe. Remove this by removing the two gold coloured screws. This should now give you easy access to the sump end of the black pipe which lead from the metering tank. Remove this and clean it out. Pop all the parts back, stand you machine upright. Reconnect the watre supply and the waste and give it a rinse cycle to test - number 1 on the dial.
Hope this helps. My apologies if any of the take apart is not completely accurate - I don't want to turn my machine over again to check!
Mark
Posted on Apr 12, 2010
Have bosch sgs 6312gb it's not filling with water in machine
If it works when water is added the the over flow switch is ok
Here is the diagnostics guide Bosch dishwasher service guide
Nov 23, 2011 | Bosch Dishwashers
I have an E1060 drop in. The unit was purchased three years ago, but major delay in construction. Installed a couple months ago, all was fine. Have yet to cook on this grill. Two weeks ago, went to use,...
Dan, did you check the circuitry and relays to the motor, as was suggested on March 29th? If the motor can't get power it won't work. It seems, that this may be the problem, since you took the motor apart and there were no broken gears and all other electrical devices work. The other resolution was to contact R.H.Peterson Company, the manufacturer for more information, if all else failed.
Mar 31, 2011 | Fire Magic Echelon E1060s2E1P51 Stainless...
Escort 8500 X50 Red K & Ka bands going crazy
As other users said the cleaning took care of the issues. So I took their suggestions because nothing to lose. I took it apart. It is very easy. Just remove 3 crews at the bottom. It has one snap-in hook at one of the corners but easy to separate it. Then I removed the metal part (aluminum die-casted, silver color) from the PCB. It is easy to remove, just remove 6 screws (I think it is 6) then pull the thing out. Inside the aluminum die-cast part is dirty. If you clean inside with Q-tip, you can see the nasty stuff comes off. I think what happens is that the nasty dust comes off then stick on the sensing elements, which might have caused false signal. Also I cleaned tiny elements inside the metal piece with Q-tip. Now it seems working normal. Hope it stays normal. Give it a try if your unit does not act normal. Better than spending $$. Good luck!
Jul 27, 2009 | Passport 8500 Radar Detector
HP won't print black, but other colors work. New refill kit...
I purchased a c6180 in Jan 09 have just got the black working fine. After pulling the nachine apart, thinking maybe to soak the head, found micro pump for ink air in black line Run copy black only (took maybe 12x25 times) then head clean Try head clean after 50 copies Voila! Black Cannot rule out that reseating all connections helped
Apr 21, 2009 | HP Office Equipment & Supplies
Grinding/Rubbing noise?
the unit has a "food chopper" inside the pump sump. it is to chop up "food" items and not bones, seeds or other items. you can keep running the unit and see if after 2 or 3 loads the noise goes away. ie: the item get chopped up small enough to go out the drain.
if it doesnt go away, then you will need to get into the wash pump and see what is stuck in the sump.
its not hard to take apart and you will find whatever shouldnt be in there.
Dec 29, 2008 | Dishwashers
PGI5BK Ink tank not recognized on MP600
You say the "original" is 3 months old? You are out of ink. Replace the cartridge. Even when there is still a little ink in the "tank" it reports back to the printer as empty. And yes it will go through all its checks and still show empty. They don't last forever even if you don't use the printer. The ink evaporates out over time.
Nov 21, 2007 | Canon Pixma MP800 All-In-One InkJet...
My DCT646-2 no one can hear me.
take it apart and clean the mic with alcohol. (I took out a black round cover it had on top to reduce eco)
Worked for me.
cheers,
Oct 04, 2007 | Uniden DCT646-3 Cordless Phone
Screen prompt kvt 617p/na
your hideaway unit might be fried, thats what happend to my unit. its the same unit and i had the same message. hope i was able to help. goodluck.
Aug 11, 2007 | Kenwood KVT-617DVD Car DVD Player
Dishwashers Logo
41 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
